Home > Puma (Tdci) > Loose pillar/roof section bolts |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 4990 |
Not heard of it Froggy, your little landy picture is saying it's a 2.2 by the way
4th Apr 2012 8:56pm |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 |
Had to tighten all mine too a few months back .... so i assume they had worked loose over time??
All got a wee drip of threadlock this time Guns and Landrovers .... anything else is irrelevant. |
4th Apr 2012 10:03pm |
I'll be checking mine at the w/e ... thanks
5th Apr 2012 7:44am |
BruceT Member Since: 01 Nov 2010 Location: South Africa Posts: 516 |
Thats LR QC for you.......when I bought mine I went through all the nuts and bolts I could find. You will be amazed at what I found either loose or missing.
For example: the anti roll bar bolts were finger tight - 19mm IIRC?. (I was able to remove them with my fingers.) I noticed them when I was standing behind the vehicle. Dont know how LR missed them in their pre delivery checks.......This is what caused me to check everything. I would say out of all the bolts I checked at least 30 to 40% of them needed tightening. Some were even missing. I never checked the bolts you are talking about though. (guess what Im doing this weekend) Another thing I did was to remove all the rubber mats, and put lights under the vehicle when it was dark. This showed all the gaps in the panels, between the doors etc etc. Some needed tightening/re aligning, some needed weather seal tape, some needed silicon. I now have a dust free Landy. |
13th Apr 2012 9:13am |
Froggy Member Since: 01 Apr 2012 Location: Stellenbosch South Africa Posts: 17 |
A great tip Bruce to find the gaps, thats my job for the weekend now also.
Cheers, Froggy. Flying the flag in a country full of Toyota's! |
13th Apr 2012 4:05pm |
marklockett2103 Member Since: 08 Feb 2011 Location: West Sussex Posts: 32 |
I had the same problem, kept finding nuts everytime i cleaned it, the the rattles in the back started after about 2k miles, took it back and was told when i collected that all but 4 had come loose and fallen off behind the trim. since then ive done around 6k miles and the rattles are coming back, just need to get around to fitting nylocs instead. my cubby box is used now to collect all the bits that drop off. still wouldnt have anything else tho.
26th Apr 2012 4:09pm |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2615 |
Boet, LR Stellenbosch found out the entire top section of the tub was only holding on by one secured bolt. This was 2 yrs after we bought the 90 and 2 overland trips fully loaded with RTT, jerrycans, etc. You're also in CL I see? If you see the driver of a blue Saab convertible waving at you, wave back -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
26th Apr 2012 4:38pm |
Sure will Naks, Obviously your top will be down as it's always sunny in Gordans bay!! Flying the flag in a country full of Toyota's! |
26th Apr 2012 4:55pm |
nidge n Member Since: 04 Feb 2012 Location: Cheshire Posts: 718 |
please excuse my ignorance Froggy. I may have a similar problem. How do you gain access to the bolts? thanks in advance Nidge |
26th Aug 2012 6:17pm |
Sorry Nidge,
I am not sure, I left it to Land Rover as it is still covered by the Warranty. Froggy. Flying the flag in a country full of Toyota's! |
26th Aug 2012 6:59pm |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3471 |
Access is easy once you've got the side, rear and speaker panel trim out the way. Steve.
27th Aug 2012 8:08am |
Regard Member Since: 08 Dec 2011 Location: RSA Posts: 251 |
I know how to get rid of the speaker and rear(small) window trim but how do you get the large sliding window trim off without destroying clips etc....?
27th Aug 2012 8:37am |
well i managed to check mine today before the rain. All ok, so now i have to look elsewhere for the squeaky, rattle above my head youve got to love defenders
27th Aug 2012 6:08pm |
sewin elwy Member Since: 08 Aug 2012 Location: Snowdonia Posts: 39 |
Yep!
Mine too! most of the tub to roof bolts loose and some nuts rattling around in the channel....result, water leaks everywhere!!! I don't think that they forgot to tighten them, more that they just sneck them up as the are frightened of distorting the roof sides as the tub is much more rigid also distortion could cause leaks at the woefully inadequate foam gasket. |
1st Feb 2013 10:31am |
