Home > Puma (Tdci) > Wading and water proofing |
pierrej Member Since: 21 Jul 2012 Location: Perth, W.A. Posts: 16 |
Hi All,
I am preparing to take my 90 out for it's first trip next weekend. There should be some water crossings, and I need some tips on sealing the compartments under the seats, and what else should be sealed on the 90. Please can you give me your experiences? Thanks, Pierre |
23rd Aug 2012 2:37am |
skoller Member Since: 27 Oct 2011 Location: australia Posts: 7 |
Water and mud can get in the cut out in the clutch housing where the ckp sensor is just under the exhaust manifold. It has a heat shield over it but that wont stop too much from getting in. I found the hole after getting my Puma back after a clutch replacement and checked things out to find that the heat shield was left off hanging on the cabling to the CKP sensor.You can see the flywheel through the hole. Not sure if it can be sealed.
23rd Aug 2012 8:02am |
Rob, Thanks for the tip. That is definitely the long term solution. If I get a Mulgo, I will weigh it up and get a quote to ship to RSA, and will let you know. Otherwise, if I have family come over, and it is not too awkward or heavy they can take one back for you.
Skollar, I am having my de-cat pipe and silencer replacement pipe fitted in the next week. I will have a look. If anyone else has experience with this I would like to hear from them as well. Thanks, Pierre |
24th Aug 2012 4:17am |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8578 |
We now have the GMB Mittelbox in stock which comes with digital voltmeter, switch, has holes predrilled for cabling grommets etc
Brendan Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
24th Aug 2012 6:12pm |
Brendan - they don't look waterproof at all?
17th Oct 2012 8:12pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7750 |
couldnt find it on your website but found it here http://www.gmb-mount.de/shop.htm?http://ww...htm~inhalt Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
17th Oct 2012 9:50pm |
