Home > Technical > Electric window |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4498 |
Could be as simple as a dodgy contact or a loose connection.Mine went on the driver's window and it was a broken wire in the rubber covering sleeve that goes from the door frame to the pillar where the hinges are. The wire used is very frail. You can pull the sleeve gently out from the pillar at the bulk head and open it up to check the wires. 1982 88" 2.25 diesel
20th Jul 2012 7:05pm |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
Thanks Guys will have a look at the wires and try Swapping the switches over...thanks for all the help
will let you know NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
20th Jul 2012 7:45pm |
Sorry - missed your reply. Thanks, all is clear now Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
20th Jul 2012 7:48pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19605 |
You will probably be able to remove the switches easily with out taking the dash out only the radio and access from the side only. This will be much easier for you then. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
20th Jul 2012 7:49pm |
Thanks custom90steve, that's my job for Sunday then NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
20th Jul 2012 8:01pm |
Good luck Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
20th Jul 2012 8:03pm |
Trossachs turbo Member Since: 14 Jul 2012 Location: Perthshire Posts: 21 |
Same happened to me,it was a broken feed wire (red) within the flexible conduit between the doorpost and door.it is a well known fault, the cables get stretched and fail.slit open the flexi conduit, and resealing with self amalg tape
21st Jul 2012 9:46pm |
Cheers Trossachs turbo, will check that 2moz when i have a play NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
21st Jul 2012 9:58pm |
Swap the switches over nothing check all the wires...removed the door card can't see anything wrong will have to get some one with a bit more knowledge than myself...thanks for all the help guys NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
22nd Jul 2012 5:47pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5424 |
Have you had a good pull at the wires between a post and door? If they are broken, which is very common, only the copper wire will be broken, not the insulation covering them.
Andy |
22nd Jul 2012 6:34pm |
I had a good look will try again but they all seemed ok NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
22nd Jul 2012 6:37pm |
Have you checked with a multimeter that there is power there? Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
22nd Jul 2012 8:43pm |
No mate don't have one will get one of the lads to have a look....I'm not very good with wires NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
22nd Jul 2012 8:50pm |
Ah right, If I was local you could have borrowed mine or I'd check it for you but not possible. I am wondering if perhaps it is a short now... Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
22nd Jul 2012 8:53pm |
