Home > Maintenance & Modifications > Rear door gas strut again |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 |
IMHO, it is great, can even hold the door on a slight side slope as well. BM52
5th May 2012 10:12pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19654 |
Good to hear. I also remember some one mentioning it was one of the best mods they've done. It begs still the question as to why LR haven't fitted as standard! It would be more use trying to hold it open with a feather than the standard bracket even tightened up And with a KM2 and wheel cover it's quite heavy. It either is opening too wide or closing one or the other depending on gradient. Even on flat ground the wind would shutit i the right direction. |
5th May 2012 10:20pm |
Michael Brindley Member Since: 07 May 2008 Location: stoke-on-trent Posts: 84 |
Had mine from Brendon which was a Nakatanga.BRilliant so quick and easy to fit.As mentioned you can park on a slope and leave door open.No chance of trapped tails or noses or being hit in the back with the door when reaching inside.You have to physically shut the door with some pressure.Would highly recommend.
5th May 2012 10:22pm |
Odin Member Since: 29 Apr 2011 Location: Aberdeenshire Posts: 237 |
Excellent bit of kit.
Get it or design a better gas strut with combined hold open latch as per land cruisers. |
5th May 2012 11:02pm |
taffrican Member Since: 14 Jan 2011 Location: Living room Posts: 622 |
I posted this request on the last "gas strut" thread and am still looking for the onfo if anyone would be kind enough to help out, what I want to know is, the length of the actual strut, as I have a few different size struts that I have salvaged from the scrap bin at work, any info appreciated.
Thanks Mike |
5th May 2012 11:29pm |
Brilliant, but opens the door fully (90+ deg) so may push OEM lamp guard to the right a bit on a Puma (depending on tyre size). Benefits far outweigh that though Tell someone you love them today because life is short.
But shout it at them in German because life is also terrifying and confusing... |
richuk Member Since: 13 Nov 2011 Location: Dorset Posts: 201 |
Have a look at this thread http://www.defender2.net/forum/topic6886.h...p;start=15 Rich semper in excretia sumus solim profundum variat |
6th May 2012 12:01am |
Many thanks Rich, you're a star
6th May 2012 12:04am |
KarlB Member Since: 08 Feb 2010 Location: Canberra Posts: 91 |
This one works a treat: http://www.mulgo.com.au/p21_Mulgo-Gas-Stru...-door.html
Cheers KarlB |
6th May 2012 5:49am |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 |
As said, a great mod, deffo worthwhile.
I did mine ... then had to do a mates after he saw it in action. both impressed .. Guns and Landrovers .... anything else is irrelevant. |
6th May 2012 12:04pm |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 980 |
Or, for under a fiver, you could fit this:
This is a broom handle, a hook and a caravan awning holder. Not pretty, but it does the job well. Merlin |
10th May 2012 1:06pm |
*lost for words* Tell someone you love them today because life is short.
10th May 2012 9:01pm |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 |
What happens when you have a trailer on? I cant open the door fully with my ifor on because of the jockey wheel, so does it not push your door into that and mark the paint??
Pete. |
11th May 2012 1:09pm |
Simple solution to that is to hold it the pro's far out weigh the cons imo though |
11th May 2012 1:14pm |
