Home > Puma (Tdci) > Cruise Control
Page 1 of 4 1234>
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
Cruise Control
Has anyone had cruise fitted to their Puma? and if so how do you get on with it? as im thinking of having it installed
Post #10688 11th May 2009 8:43pm
one_iota
Australia 2008 Defender 110 Puma 2.4 SW Alpine White
There was some info on an Autron unit discussed on aulro.com:
http://www.aulro.com/afvb/90-110-130-defen...td4-2.html Mahn
'08 Defender 110
ex '95 Disco 300 Tdi
www.aulro.com
Post #10713 11th May 2009 11:46pm
Sonic3d
Thanks for that Thumbs Up
Post #10716 11th May 2009 11:57pm
dgardel
Italy
[url=http://nakatanenga-tours.de/shop/article_TEMP4DE/Tempomat-für-Land-Rover-Defender-Td4-MY07.html?shop_param=cid%3D24%26aid%3DTEMP4DE%26]NAKATANENGA[/url]
I bought from Nakatanenga a lot.......
great products...........
Post #10726 12th May 2009 8:03am
Trevor Wright
Re: Cruise Control
I remember a previous posting on this or another forum which stated that the full cruise control functionality already exists and is enabled in the Engine Management System. It showed a wiring diagram with two switches and four wires connected to unused contacts on the main connector. If correct, then any commercial product should be relatively inexpensive? Trevor Wright
'08 90 TDCi/TD4 XS SW
Post #10728 12th May 2009 8:24am
kljw
Scotland 2009 Defender 90 Puma 2.4 SVX Soft Top Auto Santorini Black
Hi all
have been looking into cruise control to. first off, i can not find a fly by wire system that is avalable at the moment, the the two companies i spoke to at first, told me it was mechanicle, and would cost around £600.00 fitted.
i then spoke to Harry at Adroit Services - 01205 820004. he uses a company that supplies fly by wire systems. what i am trying to do, when i get time, hope fully this weekend, is take a picture of the connector on the accellerator, and provide voltage readings for each connection, in the the full throtle position and no throtle postion. this hopefuly will allow them to make the bits for the kit and supply me.
i also need to locate the speed pulse sensor, i have the wire diagreame, but need to locate it on the car, this will allow the system to maintain speed up hill and down dale as they say.
will keep ypou posted, but if you find anything different, please let us know. Cheers
keith
puer claudius
Post #10731 12th May 2009 8:51am
Sonic3d
Thanks everyone for all the posts Thumbs Up
Kljw keep us posted on what you find Thumbs Up
Post #10733 12th May 2009 9:02am
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
These are the two I have found so far in Australia.
Autron: www.autron.com.au - as already mentioned there is information on AULRO.com about this.
Command Auto Group: Pictures here - http://www.cruisecontrols.com.au/prod-cc.html
The CAG one is the same unit that I also found on a UK site. At least as far as the control panel/stalks are concerned. I can't find the URL for that site though.
I suspect if the ECM does have a cruise control sub-system then it may be available to the CANbus and therefore might be easier to get something to talk to it. I know the Puma's engine has Ford Transit origins is the ECM from the same stock or is this a Land Rover development? If it is a standard Ford unit, then this may open other options. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #10736 12th May 2009 9:56am
dgardel
Italy
Re: Cruise Control
you are speacking about TD5.......
For TDCi is a little different......
Post #10750 12th May 2009 12:45pm
Sonic3d
Puma Thumbs Up
Post #10753 12th May 2009 1:07pm
dgardel
Italy
For PUMA is a little different....
Thumbs Up Thumbs Up Whistle Whistle
Post #10755 12th May 2009 1:27pm
vogue se
Belgium 2011 Defender 90 Puma 2.4 Exclusive HT Nara Bronze
I bought for my Puma a cruise control from http://www.cruisecontrols.com.au/prod-cc.html, but didn't had time to install it.
Hope it won't be too difficult.
Post #10808 13th May 2009 9:29am
one_iota
An Australian mob...just up the road from me in Sydney....it looks like the Autron unit.
What are the installation instructions? Are you able to post them here?
Some of the Aussies here are descended from convicts transported from the Old Country so we are a little suspicious. Wink Mahn
'08 Defender 110
www.aulro.com
Post #10819 13th May 2009 11:35am
dm_td5
Mahn, as I understand it the CAG unit is totally different to the Autron kit. I'm still looking into this as I'd really like CC for the round Australia trip starting in 6 weeks time. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #10826 13th May 2009 12:06pm
Trevor Wright
In my earlier post it seems I was describing the Td5 ECU when saying you only needed four wires and two switches to exploit the inbuilt Cruise Control functionality.
So, can someone confirm, for sure, that the same or similar functionality does NOT exist in the Puma/TDCi ECU and unused pins on the multi-connector to the ECU? Seems odd it was in the Td5 and is not in the, presumably more advanced, Puma unit which also has drive-by-wire throttle control which I guess is a really useful feature for Cruise Controlling.
Thanks Trevor Wright
Post #10872 14th May 2009 8:12am
Page 1 of 4 1234>
