Home > Puma (Tdci) > Engine Warning light - I have a solution (hardware patch) |
Kez Member Since: 11 Apr 2011 Location: UK Posts: 271 |
If you like me are getting sick of annoying engine warning lights, then I have the solution. It can be installed in minutes and if required removed before sending to your main dealers (so wont void your warrantee).
Compatible with both 2007 - 2010 as well as the new 2012 model. Am currently developing a version for the SVX model (will be identical but come in a chrome container with limited edition certificate). Since fitting I have noticed improved throttle response as well as a 3mpg improvement in fuel consumption! Click image to enlarge |
17th Dec 2011 10:47am |
terrierman Member Since: 07 Oct 2010 Location: Berkshire Posts: 18 |
17th Dec 2011 11:11am |
Military Spec, I like it!
17th Dec 2011 11:34am |
No that's not Military Spec....This is!!!!! It's a sweaty sock....Combined with a tin of Heinz Spaghetti and an inflatable swimming armband you also have a female substitute when times are hard or you are in Iraq or Afghanistan....Apparently!!!! Explanation will NOT follow (use your imagination!)... Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
17th Dec 2011 1:31pm |
Ewww, that spoilt my cup of tea!
Any chance of a better shot of your steering wheel, looks interesting, also how come the metal tipped stalk (err, sounds like another joke) |
17th Dec 2011 1:41pm |
Kez,
Was going to post an 'off topic' emoticon but as it's your thread and you asked here's a link for you...both items are on the same thread, steering wheel page 1, stalk ends page 4.... http://www.defender2.net/forum/topic3993.html?highlight=croytec If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
17th Dec 2011 2:02pm |
"They serve absolutely no purpose whatsoever apart from a suitable accompaniment to my steering wheel which apart from directional control too serves no purpose whatsoever!'
Classic |
17th Dec 2011 2:05pm |
Kez, you forgot the "Hey ho to all the scoffers" bit at the beginning and the "Bling bling!" bit at the end. Try and head 'em off at the pass I say. Whatever you buy there's always Scoffers and Scorners!!!! It can prevent one from posting sometimes.....Not me!!!!!
17th Dec 2011 2:36pm |
Allan Member Since: 09 Sep 2009 Location: Perth Posts: 166 |
You poms are nuts
Allan |
17th Dec 2011 4:05pm |
Positively certifiable I'm afraid!!!! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
17th Dec 2011 6:23pm |
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1195 |
My mil light has been on for so long now i am waiting for the bulb to blow. Land Rover turn it off it comes back on Land Rover turn it off it comes back on repeat untill bored i am. If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle Weekends 07MY L322 TDV8 Vogue SE Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
18th Dec 2011 10:41am |
