Home > Technical > Vcv valve traces.. |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 311 |
After playing with the injectors and establishing they were piezo operated I wanted to have a look at the much mentioned vcv valve..
My reading on here suggests that the 2.2tdci engine isn't as prone to problems with it as the 2.4 but I took a look anyway.. After a bit probing I got that it was a duty cycled or pwm operated valve but at idle and putting on a few revs it was impossible to see any real change to the cycle.. I'm guessing I will need to be able to see it under load conditions to notice the difference.. At least I know, the signal wire now and I'll get a remote lead into the cab at some point and try again.. Best I could do today was alter the time base to view one cycle and watch the difference between idle and revving the engine.. The difference in the square wave or duty cycle alters by about 154 micro seconds I think it was.. Click image to enlarge Click image to enlarge Eventually I'm hoping to be able to look at the vcv valve against the rail pressure.. |
24th Apr 2024 5:20pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3230 |
All very interesting
I think you mean milliseconds ms rather than microseconds μs. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
24th Apr 2024 5:48pm |
That's what I'm on about.. Getting a lead into the cab that has been tapped off the signal wire and has a connector for the scope.. I already have multiple leads of various sensors in the cab that allows connection of the scope while driving.. The length of the leads isn't an issue for the signal.. Many automotive scope leads are 3meters and can be extended.. As long as you don't pick up a load of electro magnetic interference it's fine👍 |
24th Apr 2024 5:55pm |
No.. The width of the section of the square wave when it drops from 15.6v down to zero volts is 0.446 mili seconds at idle On the second trace when reved that portion of the pulse drops to 0.292 mili seconds A difference of 0.154mili seconds or 154micro seconds👍 |
24th Apr 2024 6:15pm |
Ahh right I need specs The one that sits on the nose, not numbers 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
24th Apr 2024 7:51pm |
