![]() | Home > Technical > AMR2983 Fuse Box |
pepethekingprawn Member Since: 12 Jan 2016 Location: Lancashire Posts: 54 ![]() ![]() ![]() |
Here you go. From a new spare item I have in my garage.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 603 ![]() ![]() ![]() |
I have quite a few of them, I broke up lots of 300tdi defenders some years ago.
Karlslandyz Member Since: 04 Mar 2021 Location: Southwest Posts: 1 ![]() ![]() ![]() |
Hi oldowner do you still have any 300 tdi under bonnet maxi fuse boxes about thanks
gbpmi Member Since: 12 Apr 2024 Location: King's Lynn Posts: 7 ![]() ![]() ![]() |
Good morning, Any chance you could sell one to me please? I'm partway through a 100% rebuild and the cap is missing and rear clips have broken away at some time before I had the vehicle. TIA. |
I binned them all ages ago, no-one wanted them when I offered them three years ago
OK, no worries and thank you for the reply.
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1572 ![]() ![]() ![]() |
Have you tried the likes of PAblanchards? They’ve a lot of ex mod, don’t reply to emails though you’ll have to be old fashioned on the phone.
Thank you, I have, yes. None at the moment unfortunately, but thank you again for the reply.
julian Member Since: 17 Feb 2017 Location: Devon Posts: 57 ![]() ![]() ![]() |
Mine is broken also.
It seems like just the sort of thing that someone would 3D print. Its on my to-do list but I've been hoping someone else would get there first! |
Please let me know if you do and IF you do, please improve the design and material flexibility.
Built to crack. |
Other place to try is autosparks that remanufacture looms
I tried Autosparks 2 days ago and they don't have them, but they do offer an alternative solution, although I have not pursued that yet.
Here's what Paul at Autosparks said yesterday: "Our solution on the harnesses we build is to use 3 x 655-601, clipped together makes a 3-way fuse box in its own right. When wired up replaces the original Land Rover assembly". Maybe someone with the requisite auto-electrical knowledge could explain further? |
They are saying to use three of these -
https://www.autosparks.co.uk/in-line-maxi-...-6mm-cable ...but that is no better than the broken unit, as its not like your part isnt electrically working, it just does not mount correctly. And three of the above would also not mount to the original bracket. So it would work if you had nothing at all, but is no better than a broken OEM one. |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 488 ![]() ![]() ![]() |
As the 300Tdi engine compartment fuse box distributes power from a single feed, I would suggest that this is a more suitable alternative -
https://www.polevolt.co.uk/acatalog/4-way-...HA500.html ![]() 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
