Home > Puma (Tdci) > Aircon / Heated Seats- Puma 2.2 Tdci Utility XS |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1355 |
When they're working properly the AC is cold and the seats get hot.
A common problem with heated seats is the wire becoming detached from the thermostat. Details of how to fix here, https://www.defender2.net/forum/topic76500...d+seat+fix |
11th Apr 2024 9:06pm |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3057 |
The fuel leak when filling may be the breather hose. WARNING.
This post may contain sarcasm. |
11th Apr 2024 9:18pm |
Dorothy Member Since: 14 Sep 2020 Location: East Sussex Posts: 32 |
Cheers I'll get onto that wiring check straight away. Have to get my head around what previous owners did with rear spotlight, re-connect the DRLs and fit a Blue Sea Add-on. |
12th Apr 2024 8:05am |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2055 |
we have a 2016 truck and the aircon is always icy cold...
seats are reasonable and work well IMO but maybe not how some would describe as "toasty" albeit I don't have any other reference |
12th Apr 2024 2:34pm |
Puma_MOG Member Since: 08 Sep 2017 Location: Cheshire Posts: 119 |
What seats do you have? I had the half leather standard seats first and found they felt a lot warmer than the full leather premium seats I installed after.
As for the AC, I know I will get the details/names wrong but the mixer? could be stuck and while the dial set to the coldest setting, it's actually letting some heat in. It's cable driven can they can get jammed up. I recall mine was quite sensitive on the temp control dial and the slightly touch would heat things up excessively. Good luck |
12th Apr 2024 8:12pm |
Yes agreed had the sand XS half leather and now the Premium *or whatever) full leather version ans the heat output seems less but still fineā¦
12th Apr 2024 8:51pm |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 998 |
Too cold sometimes When you press the AC switch, it'll automatically turn on the blower to it's lowest speed if the blower switch is on 0. You can of course set it to 2 or 3 to get more cold air though it wont affect the AC itself. Opening the window may actually suck more warm air up from the hot gearbox. Maybe have the AC fluid renewed. |
12th Apr 2024 9:27pm |
MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 244 |
With a digital thermometer in the middle vents by the clock my ac goes down to 3 degrees c but it does take a while to cool down the cabin and i can see the temp fluctuate as the compressor turns on and off.
The heated seats.. theres a thermistor in the seat back at the bottom and i broke mine by squeezing it with my thumb (it was stucking in my back and annoying) in the end i replaced it with a random one off ebay and the seat stays on for longer without shutting off - it gets too hot for me :/ 1953 80" 1987 mini city e 2011 90" |
12th Apr 2024 10:39pm |
BrunoJ Member Since: 14 Sep 2019 Location: Stavanger Posts: 59 |
My aircon blows really cold air.
Overall heating regulation is quite unprecise, and not very effective, for far end of the car, so rear seats passengers will have different experience then driver. Heated seats are one of worst I ever used. They are diesel-like - few minutes before you really fill something. I guess this is due to quite thick leather. Still better than nothing during winter. |
14th Apr 2024 9:59pm |
Millerdark Member Since: 16 Sep 2015 Location: Berkshire Posts: 15 |
The aircon probably needs a recharge.
6th May 2024 10:42pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7712 |
As above, keep wi down closed to reduce air bring s7ckex up 9vervgbox area that warms and ghen heats the cab. Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
7th May 2024 9:06pm |
Will get it topped up. If it doesn't need topping up, then theoretically I have a mechanical issue. 2001 Defender Special Vehicles TD5 Hardtop (Ex Scottish & Southern) Side Lockers, Side Hatches - Poorly chassis and bulkhead. (SORNd)
2013 Defender Puma Utility XS |
12th May 2024 9:04pm |
