Home > V8 P525 Area (L663) > No dipstick?!
Cheshire110
No dipstick?!
Just seen that the car doesn’t have a dipstick! Or am I missing something?
How on earth are you supposed to check your oil?
Who are these morons that make decisions like this?
Rant over Cheers, David
Post #1029952 31st Mar 2024 5:42pm
Cheshire110
The iGUIDE also makes no reference to anything other than a dipstick!
Pathetic. Cheers, David
Post #1029958 31st Mar 2024 6:11pm
TexasRover
Why do you want to check your oil? You are not supposed to open the bonnet.
Post #1029963 31st Mar 2024 6:31pm
markb110
Screw driver through the sump.
If nothing comes out, add oil. Whistle
Post #1029966 31st Mar 2024 7:09pm
lrFFM
Germany 2016 Defender 90 Puma 2.2 SW Keswick Green
Use Pivi Pro to check it.
Post #1029990 31st Mar 2024 11:54pm
Nuclear Nick
Pathetic.
The electronic monitoring system is covered in iGuide under 'Topping up the Oil'.
It could be better explained and obviously should be covered under checking oil level, which on the V8 is via the touchscreen.
Post #1030002 1st Apr 2024 7:35am
LR Nuts
I have a 'tanker' dip stick, stands at 6ft high, but tops out at 6000 Ltrs
[double click to zoom]
Post #1030018 1st Apr 2024 9:27am
Bowbearer
United Kingdom 1985 Defender 110 200 Tdi SW Auto Baltic Blue
Does the computer tell you exactly how much to top up then?
How does it work. How do you know how much to put in?
I’m never likely to own one just interested.
Post #1030025 1st Apr 2024 9:54am
Dipsticks are so yesterday!
Why have a simple near-foolproof mechanical system which has worked for over 120 years when you can have an overly-complex software-controlled computerised system with near infinite potential for failure?
It's called "progress".
Post #1030027 1st Apr 2024 10:05am
Ianh
I’m with you on that one Blackwolf,
I’m completely saddened by the lack of good engineering sense that has resulted in the removal of engine oil dipsticks, and the earlier removal of auto transmission dipsticks.
I really hated when they stopped using dipsticks on auto box’s. Now for most automatics you have to get the box to the right temperature, monitor that with a diagnostic tool and top up until ATF dribbles from a fill hole. In practice that means you have your hands in tight and very hot spaces with the engine running and then have hot ATF pouring over them while refitting the filler plug !!!
Post #1030059 1st Apr 2024 2:04pm
Nuclear Nick
Mine’s only ever told me the level is ‘OK’. Under ‘Topping up the Oil’ in iGuide it says: ‘For engines with an electronic monitoring system:
Add oil, as indicated by the engine oil level indicator messages in the instrument panel’.
Here’s what mine currently indicates:
Interestingly, OTA update 4.1.1 states for the V8 Defender ‘Improvements to engine oil monitoring systems’, whatever that means.
Post #1030067 1st Apr 2024 3:11pm
TexasRover
My previous LR v8 products had this, you could actually read out the calculated volume with the IID tool. Never really liked it though too cumbersome.
My Beemer also has this, which is handy as it warns you when it starts to run low (I had a small leak) before it is too late. but it also has a dipstick. Hurrah!
The other problem with not having a dipstick is that when you change the oil you have no means of checking if you are too low or too high, so you have just do it by making sure you know the volume you are putting in. You also never look at your oil ...
All of this is irrelevant to most users who never ever open the Bonnet.
Post #1030068 1st Apr 2024 3:25pm
