Home > Td5 > Factory TD5 rev counter plug and play?
2hel
United Kingdom 2003 Defender 90 Td5 CSW Java Black
I've managed to find a rev counter that comes with the factory loom from the clocks... would this be a simple plug and play into the connector and it would work or is there more to it than that? Was hoping to just swap the clocks over and plug it in.... is this too optimistic Laughing
Rev counter is on the left
Post #1025545 21st Feb 2024 10:48pm
rallysteve
You will need to run a cable from the ecu. I believe ABS vehicles have a cable already wired to the correct pin but it doesnt go all the way to the dash. 02' 110 TD5 Double Cab Rebuild Thread
84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale
Post #1025550 21st Feb 2024 11:55pm
Zimblewinder
Australia 2000 Defender 130 2.5 TD HCPU Chawton White
just so you know my 2000 130 also had the grey wire from #19 pin, to the block behind the dash binnacle; just not to the tach.
Post #1025555 22nd Feb 2024 8:03am
2hel
That's typical I was hoping to avoid that by having part of the loom. Nevermind!
I don't think my 2003 TD5 has ABS so hopefully the pin 19 is spare. In my quest for OE finish I assume I can run the cable from pin 19 and then plug it into the back of wherever this black cable meets the harness behind the dash? I.e Trace the cable circled to the connector on the dash loom and should be blank on the other connector? Haven't explained that well but hopefully makes sense Laughing
Post #1025556 22nd Feb 2024 8:04am
Zimblewinder
just so you know my 2000 130 also had the grey wire from #19 pin, to the block behind the instruments; just not to the tach.
Post #1025557 22nd Feb 2024 8:04am
2hel
I guess the grey was for ABS?
Post #1025558 22nd Feb 2024 8:05am
Biscuits
United Kingdom 2001 Defender 90 Td5 CSW Epsom Green
I have to fit an OE rev counter to my 2001 TD5 and have fingers crossed the grey/white ECU wire is behind the dash. Car does have ABS... well, at least an ABS light comes on when I start Razz 2001 90 TD5 SW - Juice Motors Resto Mod - Epsom Green
2024 90 D300 HSE X-Dyn HT - Santorini Black
Post #1025603 22nd Feb 2024 3:23pm
rustandoil
I ran a wire from the ECU when I fitted my rev counter...at the time I was unaware that there might already be a wire in the instrument binnacle...where should I be looking next time I'm in there poking around?
Post #1025607 22nd Feb 2024 4:06pm
Martin
Site Admin
In the plug (bulkhead side), pin 14 is the rev counter signal, usually WHITE/GREY.
It's one of the corner wires, if you have corner wires of WHITE/GREEN, GREY/BLACK, GREEN/BLUE and an empty corner then you're out of luck.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1025609 22nd Feb 2024 4:11pm
rustandoil
Excellent info... thanks Martin Thumbs Up
Post #1025610 22nd Feb 2024 4:21pm
2hel
But if I have a blank corner on mine I can run the ECU wire to that connector and then just plug and play from the binnacle loom?
Post #1025775 23rd Feb 2024 10:44pm
2hel
Does anyone know the pin types for the dash loom connector?
Post #1029764 29th Mar 2024 6:46pm
PaulMc
The Grey 14-way connectors are Sumitomo HD090 Series Connectors.
Male connector on the instrument harness, female connector on the vehicle harness.
I have both male and female terminals. Paul.
Post #1029769 29th Mar 2024 7:20pm
2hel
Brilliant thanks for letting me know typically I only need one 😂 I'll have a search unless you have some spare I can buy off you?
Post #1029771 29th Mar 2024 7:26pm
PaulMc
I have plenty - I sell them (in 10's) on eBay Very Happy
I'm happy to sell you just one, they're £0.30 each - but the stinger is the postage Shocked
'Large Letter' has just gone up to £2.10 for 1st Class.
. Paul.
Post #1029776 29th Mar 2024 8:11pm
