Home > For Sale & Wanted > [For Sale] Steering box - 4 bolt type for refurb. |
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1568 |
Mine is leaking where did you get your new one from?
16th Mar 2024 3:11pm |
Joncorry Member Since: 03 Apr 2022 Location: Cheshire Posts: 151 |
The new box was a truwsteer from SP4x4 in Liverpool. It wasn’t the best experience with them to be honest.
The box went in but you have to carefully reshape the smaller metal pipe to make it fix the new location, bit of a faff but doable. The new box is quite positive in feedback (as good as these are) and the air bled out ok. 2003 110 G4 used in 03 and 06 events - its well travelled. 2002 Range Rover G4 Event car (Australian leg) 2008 Discovery 3 G4 UK Selections car 1968 Series 2a |
16th Mar 2024 8:04pm |
I’ve ordered one, already in the post. 24 month warranty so hopefully all will be well. Cheers for the lead
18th Mar 2024 4:55pm |
When you say you had reshape what did you do. I’ve managed to get it to the location but the pipe doesn’t want to locate.
Sorry to bother you. |
27th Mar 2024 10:10am |
The advice I was given (via a facebook search) was to make the pipe fit. Gently and slowly bending the hard pipe will allow it to fit the new location, don't rush it as the pipe can fracture and that's a new problem to sort.
I'll try and find a picture. It's a bit of trial and error to get it in the right position but it does fit eventually. The supplier was less than helpful, point of sale and money extraction is very efficient but after that... disappointing is the politest term I could describe it as. 2003 110 G4 used in 03 and 06 events - its well travelled. 2002 Range Rover G4 Event car (Australian leg) 2008 Discovery 3 G4 UK Selections car 1968 Series 2a |
27th Mar 2024 10:57am |
This is the pic I was given on fb
Click image to enlarge This is final bend of my pipe where it reaches the port. Click image to enlarge 2003 110 G4 used in 03 and 06 events - its well travelled. 2002 Range Rover G4 Event car (Australian leg) 2008 Discovery 3 G4 UK Selections car 1968 Series 2a |
27th Mar 2024 11:02am |
We ended up skimming 0.3 of a mm off the pipe. Fitted then. I haven’t driven it yet as it’s in a body shop having all the corrosion sorted. But my mate said it felt better just moving it around their yard.
27th Mar 2024 8:50pm |
Sorry to invade your for sale page.
Hopefully someone is in the market for a original box now 😗 |
27th Mar 2024 8:51pm |
