Home > Puma (Tdci) > Coolant Hoses |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 250 |
I think the main large bore hoses from engine and around the radiator are about 35mm int Diameter. not sure about the smaller ancillary/heater hoses but if you can wait for about a week ill tell you for sure as I have a full set of the original rubber hoses off the 2.2 in a bag in the loft at home...I replaced all mine with silicone but kept the originals...
when I get home ill have a look if you don't get a firm reply from someone else before that.. |
15th Mar 2024 9:26pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7701 |
Self amalgamation tape, inner tube snd cable ties plus jubilee clips. Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
15th Mar 2024 10:10pm |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 644 |
Thanks Andy that would be much appreciated.
15th Mar 2024 10:11pm |
Hi.. Just home last night and remembered thisππ..
Had a look and the hose set basically consists of two main diameters.. The large bore ones are 33/34 mm And the smaller 17/19mm.. Those are just measuring the hoses as they are nowπ Click image to enlarge |
23rd Mar 2024 9:07am |
Many thanks - much appreciated
Meant to ask - is that internal diameter? |
25th Mar 2024 9:04pm |
Sorry.. Yes.. Internal.. π
26th Mar 2024 1:31am |
