Home > Puma (Tdci) > P167B41, power loss and engine vibration in 5th/6th gear |
rbsn Member Since: 12 Mar 2024 Location: Itajaí Posts: 1 |
Hello! Greetings from Brazil.
My Defender 110 with a Puma 2.4 engine (2008/2009) recently had an injection nozzle stuck open and melted the piston head. I overhauled the engine and the injection pump, changed the injection nozzles (Denso) and isolated the EGR valve (physically and with remap). Now I'm experiencing a noticeable power loss especially in 5th and 6th gear, between 2000 and 2500 RPM, along with engine and panel vibrations. I recorded a short video trying to demonstrate it: https://www.youtube.com/shorts/vNeR8Xw6rbg The engine noise is also a little harsher than before, especially in this RPM range. The mechanic thought that the lack of power could be a problem with the turbine, as it was the only thing that hadn't been checked yet, but today I used an cheap ODBII reader and got the error code P167B41 (pilot correction learning process). The workshop that changed the nozzles and overhauled the injection pump says it has done this learning process and that this error code should not be appearing, but will redo it. Could this learning process be the cause of the power loss or could be something with turbine too? Thanks!! |
13th Mar 2024 12:34am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19620 |
Possibly VCV, which doesn’t produce a DTC and symptoms of power loss in those gears and Rev range is a symptom.
VCV failure causes poor running, and loss of power especially in higher gears / top end. In turn causes rough running, seems like a labouring engine. Possibly causing vibration etc you mention. The Injector code, may just have been from the learning process and should have been cleared at the time. IIRC, the injectors need to be put through the learn process, the VCV doesn’t as that self learns over time. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
13th Mar 2024 7:13pm |
