Home > Puma (Tdci) > Puma 2.4 not starting ..... immobiliser??? |
AndreB Member Since: 23 Jan 2021 Location: Brielle Posts: 11 |
I found it behind the instrument panel Had:
Defender 90 TD5 2001 - 225.000 km Defender 110 TD5 - 2000 - 120.000 Have: Defender 90 Puma 2.4 2010 - 211.000 km Instagram: https://www.instagram.com/landrover_diary/ |
10th Jul 2023 10:45am |
Hello guys,
I experienced the same issue bu cranking and not starting. I want to try the solution with the shunt, i removed the connector but I am lost... How can I identify the pins 2-3 ? Do I need to open up the connector? Sorry but my technical knowledge is below average Had: Defender 90 TD5 2001 - 225.000 km Defender 110 TD5 - 2000 - 120.000 Have: Defender 90 Puma 2.4 2010 - 211.000 km Instagram: https://www.instagram.com/landrover_diary/ |
10th Jul 2023 11:16am |
I found the pins, now figuring out the shunt Had:
10th Jul 2023 12:06pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 1786 |
Martin, site owner can repair your Instrument cluster, just pm him.
https://www.defender2.net/forum/member-martin.html Re changing over to another used instrument cluster, it can be done but requires a lot of work on saving data , eeprom replacement and programming etc to get mileage set correctly. So far cheaper to get current one fixed by Martin. |
1st Nov 2023 6:21pm |
Landypuma Member Since: 25 Oct 2023 Location: Nottingham Posts: 3 |
Awesome I did think that is probably the case thank you I shall PM him directly.
1st Nov 2023 6:33pm |
Apparently you need to have posted 3 times to do direct messages so heres’s a third post just for fun! 🤪
1st Nov 2023 6:35pm |
xmotor Member Since: 17 Jan 2024 Location: la balme de sillingy Posts: 19 |
Hello Martin, I made your modification on my defender 2.4 TD4 which won't start. But the result is worse. It still won't start and I don't have the engine light and warm-up light anymore. I replaced the engine of the defender 2.4 TD4. New injectors, new spark plugs, etc... When it's time to start it, I plug the battery back in and turn on the ignition. The engine starts to run. I stop right away because the oil pump is not primed. I disconnect the 30A fuse under the passenger seat. And I start priming the oil pump to the starter. Once the oil pump is primed, I put the fuse back on and it won't start. I don't know to do. |
31st Jan 2024 5:17pm |
Sorry for the previous post. I had forgotten to put fuses back on. So that's OK but it still won't start. Is there a technique to purge the injectors?
what should be the pressure from the injection pump to the starter motor (non-rotating engine). I have 130 MPa. I think that's too much? Thanks for your help Olivier |
31st Jan 2024 6:35pm |
Hello
I still haven't been able to start my defender 2.4 TD4. Do we still have the DTC 1602-31 at the nanocom when we shint pins 3 and 4? My courtesy lamp works, as does the remote control but I think there are air bubbles in the injectors. I brought in the fuel with the special tool. I unhook the tool and try to start but the engine won't start |
2nd Mar 2024 12:32pm |
Jerrydi Member Since: 08 Mar 2024 Location: Tidworth Posts: 1 |
I have this same problem. My puma start and immediately cut out, the alarm light keep flashing and the fob doesn't seem to respond
8th Mar 2024 2:46pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19615 |
New battery in the fob, press it multiple times fast to sync it.
Does it then work? Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
8th Mar 2024 7:31pm |
Hello, How to do to synchronise ECM ans AS10 via nanocom? I still don't have an injector control. Is it the AS10 that's blocking? Thanks for your help |
8th Mar 2024 11:15pm |
I explained how to do it 4 days ago with my last post on your original topic on the subject https://www.defender2.net/forum/topic90991.html
On the Nanocom it’s called EMS resync and I believe it is the last option on the menu once you have selected defender, Puma, defender Puma 2.4. see the Nanocom emulator for details https://emulator.nanocom-diagnostics.com/ |
8th Mar 2024 11:26pm |
jeremy1 Member Since: 09 Mar 2024 Location: Cheshire Posts: 1 |
I’m trying to diagnose my puma not wanting to start properly, it’ll crank rev for a second or two then die. OBD reader is saying it’s due to the glow plug in cylinder 4 but by the sounds of it, it might be the immobiliser. I’ve got a video of it starting but clearly can’t post them on here. |
9th Mar 2024 12:23am |
