Home > Maintenance & Modifications > Gwyn Lewis shock mounts front. |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2262 |
So are those OME60037? if so, how do they compare with genuine gas charged LR shocks? Puma 110" SW
8th Mar 2024 3:11pm |
mark1200 Member Since: 09 Oct 2011 Location: peterborough Posts: 64 |
I have fitted them as well very well made and probably last forever lol
8th Mar 2024 4:36pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7687 |
I can check number on them. They are medium duty Std length, they are actually the 2nd set.
First ones I fitted lost an overland trip and std shocks getting very hot and failing. So upgraded to medium duty std length one shocks. 90k later they are due a change. Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
8th Mar 2024 5:56pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19579 |
These types are so much better, I have D44 ones but they are a lot easier to clean than the top hats that gets hidden corrosion.
It’s useful to use the HD turret rings as well at the same time, much more reliable. One of those jobs to be careful with doing though that’s for sure. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
8th Mar 2024 8:29pm |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2039 |
I’ve had the GL turrets fitted for years -they are Superbulous.
Also fitted the HD turret rings and spring isolators at the same time. Only wish I’d had the funds to fit Fox shocked at the time 🤪 Looks so much better and definitely makes it easier for maintenance and cleaning. |
10th Mar 2024 9:33am |
Confirmed ome60037 Cheers
11th Mar 2024 3:43pm |
Fitted these at same time, def worth doing
Click image to enlarge Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
11th Mar 2024 3:44pm |
