Home > Puma (Tdci) > Defender 2.4 Puma TDCI New engine fitted and guess what? |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5425 |
It doesn’t help you, but I doubt engine would start, and run so well if incorrectly timed. I think your problem must be something else.
A new VCV would always be my starting point on these engines. |
1st Mar 2024 10:53pm |
Jensen Member Since: 05 Jan 2013 Location: Poitou Charentes-France Posts: 20 |
Thanks for your reply !
Totally agree with you ! Best of my knowledge you Can’t check the timing now it’s all sealed and back together . The VCV was relatively new on old engine/pump . Never did a relearn because you can’t with nanocom ? But it was fine all the same . |
2nd Mar 2024 12:26am |
Surely if the timing was so far out that the pistons were hitting the valves there would be starting problems, smoke and diesel knock, fault codes ??
I want to be sure before I strip it down again to check timing ! |
2nd Mar 2024 4:24pm |
Siwynne Member Since: 04 Nov 2016 Location: West lancs Posts: 560 |
It won’t bend a valve is mistimed just break a cam follower bolt or the ladder assembly. Would run like a bag of crap too
2nd Mar 2024 4:55pm |
Yeh ! That’s what I thought .
If it was hitting the valves you would think you could hear It through the followers etc But you can’t ? |
2nd Mar 2024 5:57pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1572 |
Injectors in tight? Blowing out past them?
2nd Mar 2024 9:42pm |
Yes ! Injectors are tight ! 6nm + 180 *
Checked them twice ! Probably don’t like that 2 bolt system |
2nd Mar 2024 11:05pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2267 |
Was the CKP holder already in place in the new engine? To my knowledge this setup is done before the cylinder head is installed. I may be wrong...
As well, make sure the injectors are original Denso and not counterfit. It can be very difficult to spot the difference. Puma 110" SW ............................................................. Earth first. Other planets later |
3rd Mar 2024 2:15pm |
Hi
Yes the crank sensor holder was already on and bolted up. The engine came from a very reputable UK engine refurbisher who also supplied the Denso injecteurs |
3rd Mar 2024 2:25pm |
I would try using the older injectors. Puma 110" SW
3rd Mar 2024 2:46pm |
Is it so audible to upload an audio? Puma 110" SW
3rd Mar 2024 6:32pm |
SJM2018 Member Since: 06 Jul 2018 Location: Bristol Posts: 296 |
My 2.4 had been making a ticking sound, that I couldn't find the source of.
I had the clutch replaced when I switched to the Ahscroft output shaft and it resolved the ticking. So could it be coming from the clutch? 2011 CSW XS 90 |
4th Mar 2024 10:11am |
I don’t know ? Will have to put a vid up on YouTube and link to it ? |
4th Mar 2024 9:01pm |
Thanks for that but I changed the clutch etc last year when I changed the gearbox/transfer input Shaft for the Loff one ! It was making a noise before or after ! |
4th Mar 2024 9:07pm |
