Home > Puma (Tdci) > Intermittent power loss when driving. 2.4tdci |
Defender du Member Since: 20 Feb 2024 Location: Wales Posts: 11 |
Thanks for your help, will check the clutch switch and change VCV, it has had new injectors just before xmas due to seals leaking and chuffing. New diesel pump a year or two ago, egr replaced just before xmas, only code that was showing then was maf but the indy said the egr was stuck open so that was probably why it was showing the maf.
Last service was August. |
24th Feb 2024 10:05pm |
Can the VCV be changed without a relearn?
Tyia |
27th Feb 2024 7:00pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 1765 |
Yes it can, most don’t do a learn, just replace VCV and drive for a few miles and it self calibrates.
27th Feb 2024 7:11pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19578 |
+1 Exactly what I did. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
27th Feb 2024 7:15pm |
Thanks for the replies👍
Checked the clutch switch still had the blip when accelerating and good amount of white smoke on start up, clears when warm. |
27th Feb 2024 8:07pm |
Update- driven over a 1000 miles now clanking not returned so far, new lof clutch bundle fitted with lof output shaft. The splines were worn on the tip of the shaft.
Need to change vcv when I get time smoking on start up and a little eratic but clears when warm. New front bumper needed, seat sponges then treat the chassis in the summer, happy days👍 |
3rd Apr 2024 6:10pm |
Does sound like the VCV change would be beneficial. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
3rd Apr 2024 6:42pm |
