Home > Td5 > 110 TD5 SW replacement springs |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 807 |
The station wagon I believe has softer rear springs, but the difference is not a lot. You can go for progressive springs but might find the rear will right a bit higher.
If it is 'comfort' you are after I would go for the stock station wagon springs |
16th Feb 2024 6:15am |
kenzle8a Member Since: 12 Feb 2020 Location: None Posts: 1074 |
I would be tempted to look at Alives Custom Bilstein Advanced dampers over the plain B6. I had B6's on mine and they are pretty old in terms of set up now.
16th Feb 2024 10:02am |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 903 |
I recently replaced mine with genuine OE Land Rover coils and shocks. Land Rover actually knows what they are doing with their suspension set ups. I highly recommend using OE or genuine. I mean mine lasted 150,000Kms. I doubt any aftermarket system would do thatβ¦π€·ββοΈ
Some comparative info on both ππ» http://www.red90.ca/rovers/springinfo.html http://www.red90.ca/rovers/shockinfo.html Good luck 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
16th Feb 2024 5:58pm |
GowerDriver Member Since: 12 Feb 2024 Location: Swansea Posts: 4 |
Thanks for the advice. I will probably go for the LR springs and look at the Alive tuning dampers as you advised. βThe fundamental cause of the trouble is that in the modern world the stupid are cocksure while the intelligent are full of doubt.β
β Bertrand Russell |
20th Feb 2024 10:46am |
Castillo Member Since: 23 Nov 2012 Location: Tavastkyro Posts: 38 |
I fit few weeks ago NRC 8044/8045 to the front and RKB500300 rear... I'm really happy with this setup. I have koni heavy track with them . I have had also terrafirma +2" suspension one year (not good) and h&r -40mm springs couple of years few year ago (too hard). But. This new setup is the best I know in my opinion. Fantastic and
Click image to enlarge comfortable riding π defender 110 td5 2006 |
20th Feb 2024 4:38pm |
Thanks great photo βThe fundamental cause of the trouble is that in the modern world the stupid are cocksure while the intelligent are full of doubt.β
26th Feb 2024 7:42pm |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 445 |
I would recommend standard Genuine SW springs with Fox dampers they give a much more compliant ride qaulity than any of the Bilstein offerings.
27th Feb 2024 11:39am |
2nd Mar 2024 11:40am |
