Home > Maintenance & Modifications > Diff/Transfer case oil - EP80/90 GL4 or GL5 |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2284 |
Defenetly GL-5.
I use mineral oil for the front ATB and synthetic for the transfer case (with ATB) as it does not degrade that fast due to high temperatures (at least where I use it). Puma 110" SW ............................................................. Earth first. Other planets later |
31st Dec 2023 2:13pm |
johnlad Member Since: 18 Dec 2023 Location: Blackpool Posts: 35 |
Gl5 not recommend for any parts that contain yellow metals (brass).
Iād check with the manufacturer what they recommend. |
31st Dec 2023 3:24pm |
On a Std LT230 with "yellow" thrust washers I use GL-4. Puma 110" SW
31st Dec 2023 3:34pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5760 |
Copied from another thread/topic
Gearbox: R380: MTF94 or TRIPPLE QX ATF Dexron III LT77: ATF Dexron II/III MT82: 75W/90 fully synthetic MTF LT85 (Santana): 20/50 engine oil ZF autobox: ATF Dexron II/III Jatco autobox: Texaco 402 oil or Dexron II if not available Transfer Box: LT230: -- Pre Td5: EP80/90 -- Td5 on: 75W/90 LT230 with ATB: EP 80/90 mineral oil, not synthetic Borg Warner: ATF Dexron II/III Differential: Standard: EP80/90 With ATB: EP80/90 mineral oil, not synthetic 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
31st Dec 2023 3:40pm |
Differential bias effect on the central (ATB) diff on the transfer case is negligible, so synthetic GL5 is good for me. Puma 110" SW
31st Dec 2023 3:51pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2091 |
Funny how they say pre and post td5 even tho they at both lt230s... Ive always used GL4 EP90 Mineral in diffs and Lt230. Probably the last 50k miles or more. As suggested by Nige at Xcess4x4. Or if you have expensive diffs then use swepco. Cant comment on diffs but it does make the R380 smoother. Instagram @defender_ventures Empire Tuning - Agent |
31st Dec 2023 5:17pm |
I would not use GL4 in a (hypoid) diff. Puma 110" SW
31st Dec 2023 6:17pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3233 |
I believe that the Rover differential is a spiral bevel gear.
Not so familiar with Salisbury, but by the external look of the pinion flange, that looks hypoid. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
31st Dec 2023 7:49pm |
There is a bit of an offset from the center. AFAIK
Anyway, synthetic gear oil lasts longer on the lt230 subjected to high temperatures. Puma 110" SW ............................................................. Earth first. Other planets later |
1st Jan 2024 2:05pm |
Just an ATB up front and ATB in the transfer case. Wincheser also suggested SwepCo. A decent EP80/90 mineral as suggested by Winchester/Ashcrofts should do the job. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
1st Jan 2024 3:41pm |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2629 |
Went with Swepco, made a bigger difference than i would of thought
ATB in diffs from winchester MT82 Swep-Co 202 Approx 2.2Ltrs Needed 2.5Ltrs Sold Swep-Co 201 LT230 - 2.3Ltrs Approx Front Differential - 1.7 Ltrs Approx Rear Differential - 1.7 Ltrs Approx 5.7Ltrs Needed 6Ltrs Sold |
2nd Jan 2024 1:36am |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2098 |
Likeomg, what difference did it make, for it to be so noticable ?
Mo The Land Rover 90 - Many are called, few are chosen. |
2nd Jan 2024 6:11am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19688 |
Agree, GL4 in transfer box, GL5 in diffs. Diesel$ Live$ Matter. ā½ļøš¢ļøšØāš§š§°āļø RED, WHITE & BOOST! š¬š§ |
2nd Jan 2024 6:41pm |
According to Swepco, Swepco201 does have a GL-5 Specification. 1999 Defender TD5 110
4th Jan 2024 9:20am |
