Home > Puma (Tdci) > 2014 specification. |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2272 |
As for suspension you could check the colored stripes on the coil springs. Then you can check it out with the detailed information available in this forum. Anyway the 90" is a lot choppier than a long wheel base Defender.
There are tons of threads about this topic in this forum. Puma 110" SW ............................................................. Earth first. Other planets later |
29th Dec 2023 10:27am |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3220 |
Fitting NRC2119 with isolators at the back if a Puma HT made the ride softer while maintaining the same height. Load carrying capacity could be reduced though as they sag more for the same weight.
I fitted them to my SW and improved a bit, but not as much as with the HT as my rear springs were originally dual rate. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
29th Dec 2023 10:34am |
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1568 |
Carpet was an optional extra for clean people. My XS has the better wipe clean stuff.
I got mine new in 2014. You could buy a base model and have all the options you wanted. XS had grey painted grill and light surrounds. https://autocatalogarchive.com/wp-content/...014-UK.pdf |
29th Dec 2023 4:52pm |
