Home > Technical > Brake help please |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1728 |
Check your wheel bearing play -
HTH Keith |
11th Nov 2023 1:07pm |
MarkBrown Member Since: 03 Oct 2022 Location: Mid Wales Posts: 326 |
Yes, second the above. Jack up the wheels individually and check for play in the wheel bearings. This is because the design is such that if a wheel bearing is loose it will move from side to side and push back the caliper pistons. This then means that when you pump the brakes the first push takes up the gap between the caliper piston and disc, the second applies pressure.
Or they might need bleeding, usually due to be a leaky seal at the caliper or split pipe/ union / perished hose. If they only do this when hot, a good start would be to change the fluid - the darker it is the older it is, as a guide. Hope this helps. |
11th Nov 2023 1:21pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2266 |
It sounds like air in the system. Now uf you push the pedal up to a hard point and then travels further down then the master cylinder could be the culprit. Puma 110" SW
11th Nov 2023 1:55pm |
