Home > General & Technical (L663) > Configurable TR |
DFNDER Member Since: 02 Oct 2023 Location: Perth WA Posts: 60 |
You need to tap the icon on the Pivi screen to select.
19th Oct 2023 8:34am |
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 370 |
What has anyone set these parameters at when using TR, its quite complicated to know best settings?
Just before going off-road select AUTO. Really incredible what it can do, also on wet roads. When situations change or coming more demanding choose the right modes or lock everything in configurable. No Mud flaps for my 90.! ----------------------------------------- P300 S MY21 on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
19th Oct 2023 3:42pm |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1334 |
There is a way to select it with the rotary knob as it does on mine although mine was enabled by Hunters Prestige. I'm not at home for the next few days so can't check my ccf file, hopefully somebody else will chime in with the setting Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
19th Oct 2023 4:14pm |
aquascape Member Since: 08 Mar 2023 Location: Sutton Coldfield Posts: 198 |
I wonder if it’s anything to do with ‘with timeout” or without timeout’.
A few settings in the gap tool have these options but nobody seems to know what the difference is |
19th Oct 2023 8:01pm |
Nashvegas Member Since: 25 Dec 2021 Location: Portland, Oregon Posts: 35 |
Here's the answer - To get Dynamic mode to be selectable with rotary. It’s 777 down below
EUCD - 245 Dynamic 1 set to “Dynamic 1 Content with Configurable Dynamic Mode Screen” MultiCAN - 562 DynamicProgMode. Set to “Available for Selection Without Timeout” MultiCAN - 605 ConfigDynamicMode. Set to “Fitted” MultiCAN - 682 DynamicLiteMode. Set to “Available for Selection Without Timeout” MultiCAN - 777 Ter Dyn Select In FCPB. Set to “rotary used for selection within touch screen” (Note I also tried 778, but it didn’t make auto selectable via rotary) |
22nd Oct 2023 6:33pm |
It’s configurable terrain response that can’t be selected via rotary, only via touchscreen, not dynamic mode?
22nd Oct 2023 8:10pm |
sullivan1337 Member Since: 24 Oct 2023 Location: Pittsburgh Posts: 8 |
Both are indeed able to be selected from the rotary!
https://www.defender2.net/forum/post1013294.html#1013294 24MY Defender 110 P400 X-Dynamic SE, Pangea Green. |
31st Oct 2023 4:57am |
