Home > Modifications & Maintenance (L663) > Blind Spot monitoring e rear traffic RETROFIT e PROGRAMMING |
mbso Member Since: 01 Sep 2021 Location: Genoa Posts: 93 |
WOW !! what a work !! bravissimo !! DISCOVERY 4 2013
VOLVO XC90 2017 MY23.5 110 D250 SE in Santorini Black |
30th Oct 2023 12:50pm |
Clark4x4 Member Since: 19 Jun 2023 Location: Madrid Posts: 21 |
Great work, waiting for final photos and process. Thanks for sharing!!!
Regards |
30th Oct 2023 4:34pm |
mmbanf Member Since: 16 Mar 2021 Location: Milano Posts: 132 |
Here we go, I'll try to make the point.
first operation, identify the spare parts. Right Mirror, blind spot, chromic, heated,LR129705 used 100 euro. Left Mirror , blind spot, chromic, heated, LR129699, used 100 euro. Moduli Sodr e Sodl, LR129341, LR159593, new or used, they are fine even if they come from another Land Rover, better L8b2-14f-152bx, it doesn't matter if they are from the defender, programming must be done. Click image to enlarge Click image to enlarge to finish the mirrors you need a cable that I found on ebay to connect the mirrors to the connector on the door Click image to enlarge for the Blind Spot connection, pin 41841145 , the red wire must be connected to pin 12 of the connector and the orange wire to pin 11 of the connector, the ground to a black ground wire in the mirror. Chromic, purple and blue wire to the two-pin connector in the mirror, you can find the connector here: https://www.ebay.it/itm/234402147471?var=533973894545 Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge now comes the rear part, you need two can H wires, blue and blue/green, I took them from this side connector on the central console. C32h1, then you need a dedicated power supply, taken from the junction box passenger C2BP02H-5, under the top case, white/green wire pin 5, connector. all these wires must be brought to the rear, it is necessary to dismantle the passenger seat and the rear passenger side panel, then you arrive next to the suspension compressor. in this position you also take a ground and wire the rear sensors. Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge you must then remove the rear bumper, follow the instructions in the video by Friend Simon of Powerfulluk, the modules can be installed without screws only with joints, for the connectors and pins you can find them in the attached diagrams. Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge once all this work has been done, you will have to program the sodr and sodl modules, set the correct ccf, (after setting the ccf, an alignment must be done to the central configuration, otherwise an emergency brake error will appear). you will have to vary: * EUCD-037 Blind Spot Information SystemBlind Spot Information System With Radar Direct LED * MultiCAN-794 Rear Corner RadarsRear corner radars fitted MultiCAN-723 RCTA Configuration Motion based alert for any information please feel free to ask, for the programming part I wrote in the previous post. Cheers Marco |
30th Oct 2023 6:56pm |
Wow, amazing job |
31st Oct 2023 8:07am |
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 378 |
Great work, Marco ! No Mud flaps for my 90.!
----------------------------------------- P300 S MY21 on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
31st Oct 2023 9:20am |
Moo Member Since: 01 Oct 2021 Location: Bath Posts: 1097 |
Impressive. Eiger Grey MY23 D250 SE with bits. Known as Noddy.
31st Oct 2023 10:11am |
Paladino Member Since: 07 Dec 2022 Location: Serbia Posts: 30 |
Is this somehow related to the rear exit detection?
Click image to enlarge |
5th Dec 2023 9:34am |
yes, it works in synergy with the rear radars, it must be connected to the LIN line of the door ECU.
Marco |
5th Dec 2023 10:00am |
Thanks! So these need to be installed on all 4 doors (110)? Together with the other stuff and coding
5th Dec 2023 11:03am |
coding yes, I think you can install them even on just two doors...
5th Dec 2023 11:05am |
Thank you! Last questions:) If im correct these parts on the door should inform you if you want to open the door and there is an incoming vehicle. Are they only lights or buttons that you can press?
5th Dec 2023 11:13am |
I haven't installed it, we're waiting for a response from someone who has installed it who explains how it works.
5th Dec 2023 12:09pm |
mani_jeenu Member Since: 07 Sep 2023 Location: Melbourne Posts: 12 |
can you please share a link where you got this from? |
9th Dec 2023 2:13am |
