Home > Maintenance & Modifications > Crewcab pick up |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 677 |
No drainage holes from factory.... I drilled a couple of 10mm holes in the front corners 👍🏻
25th Oct 2023 6:25am |
BuckBlu110 Member Since: 19 Apr 2014 Location: in the pub Posts: 711 |
Typical, these things leak when we don’t want them to and don’t when we need them to!
Has yours got a tailgate thresh seal? If it does then it might be worth removing to let water out that way. I suppose it depends which way you park it though? |
25th Oct 2023 8:45am |
Ive just refurbished my tub and I replaced the thresh seal, I dont know if it fits well enough to retain water though
25th Oct 2023 9:54am |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 807 |
Mine is not 100% watertight where the bulkhead meets the floor resulting in wet interior carpets.
I garage mine so is only really an issue during trips but I plan to seal the joint and possibly drilling some holes is not a bad idea. Its aluminum so no issues in terms of corrosion, |
25th Oct 2023 10:04am |
Naycrx Member Since: 11 Oct 2023 Location: Nottinghamshire Posts: 94 |
OK thanks for the replys..... for whee we park a small hole on the drivers side would work ...... .. I'll go under today have a look for the best location..... don't want to drill through anything I shouldn't
Thanks again |
25th Oct 2023 12:24pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6044 |
A couple of 90s i've had over the years, I've just drilled a hole (10mm or so) right in the top corners (like "under" the bottom of the bulkhead), there's nothing behind them (but double check first) and it let all of the water out.
So glad I've got a HiLux now.... |
25th Oct 2023 6:47pm |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 |
I did the same as above, drilled a 10mm hole in the centre at the front. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp Roy |
26th Oct 2023 3:24pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1572 |
No need to fit a bilge pump yet then
26th Oct 2023 7:18pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10545 |
I did the same but i drilled more than one hole each side as mine collects a lot of water being a 110 pick up 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
26th Oct 2023 8:47pm |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2526 |
Back in thee winch challenge days some vehicles had a fish tank pump fitted to shift water out of the vehicle.
Perhaps you could go the full works and turn it into a feature..... |
26th Oct 2023 9:06pm |
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 772 |
My 110 ragtop spends most of the year with the tail panel rolled up and nearly all the summer/autumn with the sides rolled up too. Often has a bit of a swimming pool in the back due to rain and this sloshes around merrily when driving. Unfortunately, one of the early jobs I did when acquiring the vehicle was to fit side and thresh seals to the tailgate so this doesn't let the water out very well. I cannot bring myself to drill holes in the otherwise very good rear tub.......
Click image to enlarge |
26th Oct 2023 9:09pm |
