Home > Puma (Tdci) > Raised Air Intake Removal |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 636 |
I’d leave it on, personally. You’ll have holes in the wing and windscreen surround to sort out. 2008 2.4 110 Utility XS.
20th Oct 2023 9:05am |
HardCharger Member Since: 03 Mar 2013 Location: Manila, SFO, Amsterdam Posts: 683 |
Somewhat related, I'm planning to swap mine out with a different version and I'm also concerned about the two holes in the wing. I was thinking of installing a Wolf breather cover as it may bolt onto the very same holes on the wing?
Otherwise, is there a way to cover the two holes? Like maybe a plug? I don't mind the plugs. I'm thinking that I'll just have the panel replaced with a new one when some tree or rock does not get out of the way or maybe after some pinhead in another vehicle decides to sideswipe me. |
23rd Oct 2023 6:10am |
Mike c Member Since: 11 Aug 2017 Location: Maldon, Essex Posts: 905 |
Watching thread with interest, I would like to remove my safari rai at some point.
Screwing the small windscreen pillar screws back in and leaving would be ok and rubber grommets/plugs for the wing holes may be liveable without going to the expense of a new wing which seems extreme.. 🤔 2004 Defender 90 Td5 CSW 2002 Discovery 2 td5 GS (gone) 1994 Defender 90 300Tdi CSW (gone) |
26th Oct 2023 3:50pm |
Chicken Drumstick Member Since: 17 Aug 2020 Location: Near MK Posts: 554 |
Raised intakes were official accessories. Not sure it would truly look anymore standard without it tbh...
26th Oct 2023 4:10pm |
Yes they were but it's personal taste and personally, I wouldn't fit one, unfortunately the previous owner did! 2004 Defender 90 Td5 CSW
26th Oct 2023 4:24pm |
