Home > Puma (Tdci) > P2562-34 Code !!! |
thenorthdefender Member Since: 17 Dec 2022 Location: trabzon Posts: 7 |
p2562-34 getting an error
The motor, which started moving when the ignition was turned on, became rigidly stuck at the end of the actuator's travel. All cables checked 'actuator replaced with a new one 'no grounding 'egr canceled with software Has anyone encountered this error code? [/img][/url] |
14th Oct 2023 10:14pm |
I checked them all carefully. it looks good
15th Oct 2023 7:25am |
shaun6 Member Since: 06 Mar 2013 Location: Houghton Regis, beds Posts: 46 |
Code P2562 means that Turbocharger Boost Control Position Sensor 'A' Circuit has been detected.
15th Oct 2023 9:09am |
Yes . the problem still continues
15th Oct 2023 10:15am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16972 |
If you are 100% certain the harness is OK and you've changed the actuator for a known good one (tested on another vehicle I hope) then all that is left is the ECM I'm afraid.
For some reason (usually a broken wire or grounded wire) the ECM is not detecting the actuator position from the stepper motor in the actuator and is driving it to its end stop whilst trying to position it. I'd still be suspicious of the harness and before buying a new ECM would be checking impedances and ground impedances of the actuator leads. I don't know how thorough your "looks good" means, of course, you may have done this already. |
15th Oct 2023 10:21am |
I hope it's not the ECM I'll check the cables again.
Actuator replaced with new one, still stuck |
15th Oct 2023 10:26am |
