Home > Td5 > Sudden drop in fuel mileage |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5427 |
Check your fuel pressure regulator on the cylinder head. Often leak.
23rd Sep 2023 9:48pm |
charcoal Member Since: 28 Jul 2014 Location: Hampshire Posts: 941 |
Thanks will take a look tomorrow, is this something that has to be replaced outright when leaking or will a new gasket suffice? 1999 Land Rover Defender 110 td5 station wagon
1998 Land Rover Defender 110 County Station Wagon ~ Sold 1995 Land Rover Defender 110 V8 Station Wagon ~ Sold 1985 Land Rover 110 ex mod project Tithonus ~ Sold |
23rd Sep 2023 9:59pm |
Steve B Member Since: 22 May 2009 Location: Warwickshire Posts: 586 |
24th Sep 2023 12:13am |
Are you sure? I have been driving it daily throughout the hot weather and its still been returning 30mpg up until the week before last 1999 Land Rover Defender 110 td5 station wagon
24th Sep 2023 12:42pm |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2525 |
Shrinkflation…….they’re probably mixing it with water…..
24th Sep 2023 1:19pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6043 |
Check the MAF sensor as well, especially if you've noticed that performance has dropped off a little.
24th Sep 2023 5:39pm |
No not sure, an observation after driving diesels. The weather has cooled off a little especially in the mornings. Try not using the cruise control and see If the mpg recovers, I think you can drive better without it. |
25th Sep 2023 10:42am |
I gone through a few of the points made here, MAP sensor was a little oily so cleaned that, tried driving with MAF plugged in and unplugged and felt no difference in performance with either of these. Fuel pressure regulator doesn't appear to be leaking. I did notice however that the egr valve actuator is absolutely caked in filth, maybe if this is no longer working correctly it's contributing to the loss of mileage? 1999 Land Rover Defender 110 td5 station wagon
28th Sep 2023 5:47pm |
Hazza Member Since: 10 Jan 2011 Location: North Yorkshire / Leeds Posts: 208 |
If you don't notice any difference with MAF plugged in or unplugged I'd suggest getting it replaced with a VDO or Siemens one (or better, find someone with a nanocom to test it with). 1990 Defender 110 200TDI Camper - now converted to Td5 power
28th Sep 2023 8:52pm |
