Home > Modifications & Maintenance (L663) > BREMBO 6-Pot Brake Upgrade |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2876 |
Thanks Marco, good info Andy
2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
29th Aug 2023 6:16pm |
Got these from the dealer today but does anyone know if a brake bleed and setup is straightforward on the L663?
Click image to enlarge Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
1st Sep 2023 9:13pm |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 445 |
Usually not a problem so long as you keep the hoses clamped off and system full of fluid, just normal bleeding procedure Andy
2nd Sep 2023 1:03pm |
Thanks Linds Andy
2nd Sep 2023 6:29pm |
mmbanf Member Since: 16 Mar 2021 Location: Milano Posts: 131 |
[quote="mcma1"]Got these from the dealer today but does anyone know if a brake bleed and setup is straightforward on the L663?
Click image to enlarge[/quote hello, on the Defender it is a problem..... you must first of all put the braking system , abs in service , using the gap tool or the Land Rover wizard, otherwise you will not purge anything and only errors......on the bcm. secondly, an economic system would be recommended to put pressure on the system, without this the result is not guaranteed. I'll give you a summary of the procedure. Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
3rd Sep 2023 9:44am |
The method Linds described sounds much easier Hoped myself and Mr Redman could do these some evening and avoid the main dealer. Andy
3rd Sep 2023 12:55pm |
the job is certainly not simple, this "manual" procedure should (I'm not sure) set the service mode, and give the possibility to bleed the brakes.
to apply pressure I use this economical tool. I didn't understand one thing..... you already have six-piston brake calipers on your defender, are you replacing them just for the color? Click image to enlarge Click image to enlarge |
3rd Sep 2023 2:31pm |
Yes they look really poor un painted. It is just easier and quicker to swap them out. I will perhaps have the current 6 pots powder coated and sell them when removed. Andy
3rd Sep 2023 2:37pm |
ok,
the six piston brake calipers contain a lot of oil, when you connect them, before bleeding, fill the oil tank, top it up, wait with the valves open without applying pressure and without the brake pedal until it starts to oil coming out of the valves. |
3rd Sep 2023 2:42pm |
Steve34 Member Since: 17 Feb 2024 Location: Milan Posts: 3 |
Buongiorno Marco, io ho il defender 110 2024 200 cv con cerchi da 20 e pinze piccole, secondo te posso installare le pinze come le tue? Grazie
17th Feb 2024 11:22pm |
