Home > Puma (Tdci) > Rear door table |
Ashbyandy Member Since: 17 Dec 2015 Location: Leicestershire Posts: 219 |
So details please, as it doesn’t look too bad, can you share a link for it maybe,
Thanks Andy 👍 |
18th Mar 2023 5:44pm |
Cragster69 Member Since: 15 Jun 2021 Location: Scotland Posts: 174 |
That's very interesting, I had been looking for one like this. That a few people had fitted last year.
Click image to enlarge https://www.ebay.co.uk/itm/174350764865?mk...media=COPY The price seems to have jumped considerably and there are less of them available. But at least it has been shown to work with the Defender rear door. This one looks similar to yours. https://www.ebay.co.uk/itm/234914458006?mk...media=COPY I didn't think it work with the bulge in the door card to cover the wiper motor. Looking at your pictures it might. Did the Hardware to the right side of the door card and under the handle come with it? Craig. “Don't believe everything you read on the internet.” ― Abraham Lincoln www.scotgrc.co.uk |
18th Mar 2023 6:51pm |
bodstruck Member Since: 09 May 2020 Location: Wiltshire Posts: 790 |
All the hardware and brackets came with it, but no instructions.
Brackets fit under the grab handle, under each set of hinge bolts and then one fixed to the rhs of the door. There are self tappers provided for the last one but I used rivnuts and m6 bolts instead. Here is the link: 通用 Car Rear Door Tailgate Rack,Rear Cargo Rack Trunk Shelf,Foldable Table Storage Cargo Shelf Rack,Aluminum Alloy (for Land Rover Defender 2004-2019) https://amzn.eu/d/2hqWqvJ And a pic with just the brackets fitted: Click image to enlarge |
18th Mar 2023 7:04pm |
s55shh Member Since: 30 Dec 2019 Location: staffs Posts: 186 |
how far does it protrude inside the rear when the door is closed? I like the look of it but it might conflict with my rear drawer storage.
18th Mar 2023 7:35pm |
Protrudes 60mm from the bulge over the wiper motor.
19th Mar 2023 1:42am |
webbug Member Since: 12 Jul 2023 Location: Dubai Posts: 28 |
How’s it holding so far? Does it rattle on bumpy roads?
1st Aug 2023 6:40pm |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 300 |
Picture of the one I got and fitted
Click image to enlarge And it sits pretty flush.. You can just see the top in this photo Click image to enlarge |
1st Aug 2023 8:43pm |
All good so far. Did a four day trip of lanes in the Penines recently, many of which were very bumpy and the table was fine. No rattles and hasn't shaken itself to bits
Very pleased so far. |
1st Aug 2023 8:45pm |
The price seems to have jumped considerably and there are less of them available. But at least it has been shown to work with the Defender rear door..... ... ... ... That's the one I got and fitted.. In the pictures above.. I doubt if I've had it more than a year and I'm pretty sure it cost about £70.. So going on that link its doubled in price |
2nd Aug 2023 7:39am |
MrEnglishman Member Since: 20 Sep 2023 Location: Norwich Posts: 3 |
Hey Andy. Looking at that very table on Ebay for my 2003 Defender. Did you only attach it to the door card, or did you drill holes in the actual door to hang it? I like the idea of a £46 table: https://www.ebay.co.uk/itm/284617877959?it...R8CQ8o7rYw
Fitting wasn't too bad. All aluminium so bot sure about long term strength but should be fine. Time will tell I suppose. Quite pleased with it overall [/quote][/quote] |
8th May 2024 7:20pm |
That an excellent price if its genuine👍.... Edit.. Sorry it is as you have already got and fitted it👍😂
Mine is fitted to the actual door, using riv nuts.. I'm not sure the card would be up to taking that as a fixture.. |
8th May 2024 9:09pm |
Thanks for getting back to me Andy. I noticed you mounted it just underneath the bulge on the back door, and it goes slightly under the bottom of the door card, when folded away. Does the door still close ok? Mine's a 2003 TD5, I wonder if my door card is different. I don't have the 31cm in height (below the bulge) when the door is closed. Yes, £46 delivered for a tiny table seems more reasonable than some prices I've seen.
9th May 2024 11:56am |
It's all very tight but the table just fits in and rhe door closes fine. 👍The door and card accommodate a rear wiper motor, so may differ from some..
I had to cut a couple notches in the wood panels I used to kit the back with to allow the door to close but that was it.. Pictures attached.. Click image to enlarge Click image to enlarge Click image to enlarge |
9th May 2024 12:37pm |
khamuul Member Since: 14 Oct 2017 Location: Teutoburg Forest Posts: 20 |
Hey Andy,
you dont have a picture of your attachment from inside the door, do you? Thanks Martin |
19th May 2024 5:53pm |
