Home > Maintenance & Modifications > Webasto sunroof |
Photos please?
27th Jun 2023 8:05am |
Poulstonb Member Since: 30 Jun 2022 Location: Styal Posts: 87 |
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
27th Jun 2023 6:12pm |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1729 |
It looks very similar to one that was fitted to my 100".
Lift the glass out and clean the seal really well, if the front two 'tongues' unscrew from the glass remove them, flatten them a very small amount to increase the pressure on the rubber, put a thin smear of vaseline on the rubber and refit and test. If you open it you will have to remember to clean and regrease the seal periodically. HTH Keith |
27th Jun 2023 8:46pm |
I’ve tried resealing it which between metal and frame is fine but water gets between glass and rubber . Tried cleaning and greasing to no avail.
Want to either replace with same or a double glazed option. |
27th Jun 2023 8:49pm |
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1754 |
I've always had positive results using silicone pipe grease on the rubber gasket
2nd Jul 2023 5:58pm |
It would be worth contacting someone like https://www.bristolsunroofs.co.uk/index.php as they will be able to direct you a bit better.
3rd Jul 2023 9:37am |
Tried the phone number but not working . Does anyone know if they’re still open ?
3rd Jul 2023 8:16pm |
Struggling to find anything to repair or replace the sunroof so gone for a double glazed unit from vehicle Glazing Specialist.
Hole size is slightly bigger so will need to do some nibbling Wish me luck |
4th Jul 2023 7:24am |
Installed the double glazed unit from VGS
Looks great. Glazing silicone supplied was awful stuff to use but did the trick |
1st Aug 2023 10:19pm |
