Home > Puma (Tdci) > Puma 2015 110 XS Location of Front Screen Washer NRV |
Albarker55 Member Since: 02 May 2022 Location: Fleet, Hants Posts: 22 |
These are the ‘in-line connectors’ between the reservoir and the bulkhead. Haven’t discovered which line is front and which is rear yet!
Click image to enlarge |
15th May 2024 4:32pm |
hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 339 |
Check https://www.defender2.net/forum/topic50670...p;start=60 and start with page #4.
Your picture show the NRVs. I would start cleaning them and see if it makes a difference. |
15th May 2024 5:00pm |
dotom Member Since: 04 Feb 2012 Location: Dortmund Posts: 90 |
It's also possible that someone twisted the washer to paint the windscreen frame or to pull it tight. When it's turned the wrong way in return, the hose is bended and don't let water through. You can see it if you remove the radio and check the hose. Ask why I know it....
Best regards Tom Defender 90 XS, 10-2015, Corris grey |
15th May 2024 6:06pm |
Click image to enlarge Many thanks for the reply quick responses. I had a closer look at the reference above and did notice a similar connector. did wonder what the ‘in line connectors’ were. I have a replacement NRV p/n AMR6676 (photo below) so was looking for something that looked like that! I will remove the NRVs and clean them and replace the front with my new part. Update: Black NRV was front washer and now replaced with AMR6676. Front washer system now working as it should be. Job done. Thanks again for your help |
15th May 2024 6:53pm |
