![]() | Home > My Defender > 110 Puma to M57 and 8 speed auto |
biasbilt Member Since: 05 May 2024 Location: Devon Posts: 3 ![]() ![]() |
I wouldn't try to use the PCS controller, would go straight to Turbo Lamik
mata Member Since: 24 Jan 2014 Location: Manchester Posts: 152 ![]() ![]() ![]() |
Oh, I thought you meant in your previous post that you were using a PCS ECU.
Same advice stands though, would suggest you check with Lamik about integration with your ECU. |
