![]() | Home > Technical > TDCI collapsed air filter |
| Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2559
I have the same Nakatanenga wingtop setup which includes the powder coated stainless steel snow cowl. I have not measured the cross sectional area afforded by the Snow cowl , noting it’s just a cover not tubular, however I would say it’s at lest 1.5 - 2 times bigger than the large bore ( circa 90mm diameter) circular hose it feeds into (which is secured to a plate that attaches to the wingtop).
Thefore this setup affords the ability to deliver far more air to the filter box than the std setup, with the limiting factor being the much larger bore circular intake hose, not the Snow cowl. You can see the components in this link https://www.4x4overlander.com/product/naka...ender-td4/ |
| Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3363
I have one of those Nakatanenga kits brand new for sale in classifieds if anyone wants. Plus another matching snow cowl for other side. WARNING.
This post may contain sarcasm. |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8494
I looked st this in detail before for my m57 intake, 100mm pipe and couldn't get dims of snow cowl openingnfornthe naked one. I presumed 40mm x 180 working off variation on other after market cowls. Csa 7200 which for 90mm pipe works fine although not quite there to 100mm pipework. Hence interested to know nak dims. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
| All times are GMT |
