![]() | Home > Modifications & Maintenance (L663) > Just can’t stop modifying |
| LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1314
Click image to enlarge spot others. ??? Twin rear fog/reflectors. Strengthened rear quarters [double skin'ed] the two [small] square lamps become REAR DLRs. Separate to to the rear tail lamps. |
| sasa Member Since: 05 Mar 2024 Location: ceska lipa Posts: 74
what color did you paint the exhaust system please? do you mean the logo sticker? |
| Huwcil Member Since: 08 Oct 2025 Location: Ceredigion, Wales Posts: 35
Well spotted.
The exhaust and the back of the rear suspension arms were scrubbed with alcohol then sprayed with heat resistant matte black which is widely available and made for exhausts. This is a cheap and effective alternative to the available black mild steel shields sold by customisers. My solution is very easily applied and will not rust or fall off or rattle. For the photo, the suspension is raised and camera lowered, so the silver differential is normally hidden. The silver parts under the bumper annoyed me so I fetched an aerosol tin of exhaust black and ‘sorted’ it. The logo sticker is a quite substantial cast alloy, far better quality than originally fitted to Land Rover station wagons which were thin pressed alloy, pop riveted on. I glued mine on so as not to damage the body. Bought that from an eBay seller. |
| All times are GMT |
