![]() | Home > Puma (Tdci) > 2.2 Oil Pressure Warning Light |
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6736
If the cluster displays the service message, it also holds the oil pressure warning light on whilst the message is displayed.
When the cluster changes back to showing the mileage, the oil pressure light will go out (if it should go out!) 1988 90 Td5 NAS soft top
2015 D90 XS SW |
| cd110 Member Since: 21 Aug 2023 Location: Surrey Posts: 27
ok that makes sense, but weirdly I wasn't getting the oil service message until this week. But I'm guessing it probably should have been displaying as the light was staying on, which ties in with it happening exactly 1 year after the last reset.
I think I can sleep a bit easier knowing that's the case! |
| macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1139
Frankly I read the OP's long post only after Martin's reply. And I don't mean the following to be unkind in any way, but professionally I sometimes have to deal with overthinking both when testers report errors and also with myself when I think about technical solutions This post is a great example for what I see with many engineering fellows (including myself), and, again, I mean this in a positive way. These kind of stories keep us 'grounded' as often we forget that sometimes, only sometimes, the solution is actually very simple indeed - if you ask the right guy So thank you both. |
| Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3657
This is interesting as I created one thread cause of similar issue but never knew that it was connected to the service message. I never bothered to reset that as usually just service on time rather than milage. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
I did debate trying to write a more condensed version but there's nothing worse than someone posting something and then people spend ages trying to tease information out to get to the answer! Thankfully I got there first go thanks to Martin! |
| All times are GMT |
