Home > Puma (Tdci) > Blower switch slider problem
GJO
United Kingdom 2016 Defender 110 Puma 2.2 Heritage Edition SW Grasmere Green
Hi,
I have a 2015 puma, and the blower motor is intermittent and there is some odd behaviour with the switch.
When the ignition is on, but engine off everything works. With the engine on, the blower is intermittent. If the fan speed is moved above 1, the stereo power goes off and the blower definitely won't work. I'm guessing it's a grounding issue or similar, has anyone got any pointers as to where I should look for the cause?
I have a video of the problem: https://www.dropbox.com/scl/fi/o87offnym8m...r&dl=0
Post #1077194 9th Oct 2025 10:17pm
HardCharger
Your ignition switch is most likely kaputt No Better Friend, No Worse Enemy
Post #1077203 10th Oct 2025 5:04am
