Home > Td5 > TD5 2003 recommissioning
Braidenoch
United Kingdom 2006 Defender 110 Td5 PU Alaska White
TD5 Defender 110 2003
I'm recommissioning this machine having been on SORN for 3 years. The engine oil is as fresh looking as when it was laid up, is there any need to change it before re-registering? It was serviced not long before lay-up. Thanks
Post #1076197 25th Sep 2025 9:52pm
4RF RDS
Run it for bit then change it. Thumbs Up 2020 range Rover Mk IV Autobiography PHEV
2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
H. L. Mencken (1880 - 1956)
Post #1076247 26th Sep 2025 6:34pm
Notyalc
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Re: TD5 2003 recommissioning
Maybe undo the sump plug and run some oil out before you do anything. Any water and crud should be in the bottom. Then top up and run, then change after say 500 miles.
Post #1076250 26th Sep 2025 7:18pm
