![]() | Home > Puma (Tdci) > Two presses to unlock |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2526 ![]() ![]() |
It means the fob battery is low,. At some point, as an additional indicator that the fob battery is low , the red Alarm light on the dash that blinks when alarm is activated stays on as a solid non blinking light even when alarm disarmed and engine running.
You need a quality genuine CR2032 battery, I.e Panasonic or Varta. Change battery and re sync - With the doors shut press lock four times in quick succession, then unlock once , doors should unlock and all be back to normal. |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4338 ![]() ![]() ![]() |
Thanks, I'll sort it today. 2007 110 TDCi Station Wagon XS
