![]() | Home > Technical > TD5 - ABS Modulator / ABS ECU Connectors |
jonny Member Since: 10 Mar 2013 Location: North Wilts Posts: 227 ![]() |
Hi
Does anyone have part numbers for connectors for both ends of the ABS loom for a TD5 Defender? I don't have ABS but was looking to reuse the unused connectors/wiring for other purposes.. Engine bay end appears to be : https://www.lrworkshop.com/connectors/defender-2002my/C0501 ECU End appears to be the purple connector : https://www.lrworkshop.com/connectors/defender-2002my/C0506 I want the mating parts to those, but I've no ideas on part numbers or if they are even available! Thanks Jon |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6709 ![]() ![]() ![]() |
Mating part to C0501 is a 13 way Econoseal III 070 male e.g. https://www.3waycomponents.co.uk/product/1...ector-kit/
Mating part to C0506 I will investigate ![]() ![]() ![]() |
