Home > For Sale & Wanted > [SOLD] LOF Full AP Brake Kit / Pioneer Hoses / TRW Servo
Dick
United Kingdom 1994 Defender 90 200 Tdi HT Shire Blue
A full OEM+ Brake Kit for Land Rover Defender 110 Td5 non-ABS.
The Pioneer hose kit is for 110 Td5 without ABS and with bias valve.
The LOF kit is for defender 110 Td5 without ABS and with discs front and rear.
Everything is brand new in box never fitted purchased at the beginning of the year.
1) LOF Brake Kit
- Front AP Vented Calipers with Stainless Pistons
- Road Spec Vented front Discs
- Road Spec Front Pads
- Fitting Kit
- Timken Wheel Bearing Kit
- Rear AP 110 Calipers with Stainless Pistons
- Road Spec rear Discs
- Road Spec Rear Pads
- Fitting Kit
2) LOF PowerSpec Servo Kit
- LOF PowerBoost Servo Adapter
- TRW Servo
- TRW Brake Master Cylinder
- TRW Bias Valve
3) Pioneer 4x4 stainless braided brake hose kit
- Full set stainless braided hoses for 110 Td5 non-ABS with biasvalve
- extended +50mm front flexis
- black
If you have a Defender 110 Td5 without ABS and with brake bias valve this is a holistic kit to replace the entire braking system and then enhance it even further with the power boost servo adapter and uprated TRW servo.
The difference this will make to braking is significant, not just from refreshing likely rusty old and used components but by adding the stainless hoses and the powerboost adapter and uprated servo.
I had this kit fitted on a 90 200tdi in the same configuration as above and it was a massive difference.
This is also a very easy and quick job to do, and doing the whole system at the same time with entirely new parts is far easier than trying to add new parts in piecemeal.
Additionally - The Original Spec highest quality (the same calipers used by land rover from factory) AP calipers that are used in this kit are no longer available to buy.
Over £2k worth of parts with the master cylinder and bias valve additional to the LOF kit - if youre rebuilding a 110 Td5 this will save you a significant amount.
Ideally collection from central london but the parts can be shipped in a multi shipment bundle - cost covered by the buyer
£1250
[/u]
Post #1074487 1st Sep 2025 11:51am
