![]() | Home > In Car Electronics > ARB Compact Compressor Wiring |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8486
Does it work when you connect red and black up?
Think they have a warth suited relay off a pressure switch but if you just want on function then just use +ve and -ve througha relay. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Think the yellow is a switched live to air locker switch which you don't need. Cheers
| Mago Member Since: 25 Apr 2021 Location: Frankfurt Posts: 43
Here we go:
Click image to enlarge Defender 110 Puma 2.4 |
| boode Member Since: 11 Apr 2012 Location: Devon Posts: 438
Perfect - thank you
