![]() | Home > Tdi > Injector pump timing with DTI and EGR |
Fossil Member Since: 23 Aug 2015 Location: Bolton Posts: 26 ![]() ![]() ![]() |
I use a setting of 1.6mm for the timing, as opposed to the 1.54 or 1.4. I think, as it's a UK 300tdi and using the pins to set it it goes (or did before the FIP rebuild) to 1.4 ish, it had EGR. It seems to run a little better with a bit more advance than the 1.4, and it has been like that for years with no issues. I suggest to try to get tight fitting pins for the timing, you can see a slight waggle makes a difference on the DTI. You can lock the pump at the desired lift position, and having pulled the pulley off, reset it at your chosen advance position, then unlock the pump, or probably best initially just adjust the FIP pulley with the 3 bolts (a bit fiddly but very doable with minimal disturbance and easily reversible).
MercianRover Member Since: 07 Apr 2022 Location: Culworth Posts: 166 ![]() ![]() ![]() |
Thank you, thought I'd seen another measurement somewhere besides 1.4 and 1.54.
