Home > Tdi > 200TDI handbrake drum oil seal leaking
cykoh85
Malaysia 1990 Defender 110 200 Tdi SW Santorini Black
Hi all,
Does anyone know about any clip/circlip staked nut on the rear output shaft (30mm nut, as shown in the attached photo with the red circle)?
I tried to remove it yesterday but it was very difficult, so I gave up and just refilled with new oil.
My next question is: if I want to change the oil seal next week, do I need to drain all the oil again?
thank you.
*photo obtained from Land Rover Forum.
Post #1073463 16th Aug 2025 6:49am
Retroanaconda
No. Depending on the angle you’re parked at you might lose a bit but you can just top it up if so. No need to drain the transfer box.
Post #1073464 16th Aug 2025 8:00am
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
Think that picture is the 300tdi setup, 200tdi should be with the expander and adjuster on the left & right.
What did you struggle with? Was it getting the nut off, or pulling the flange off after removing the nut?
The flange can sometimes be a bit of a tight fit so may need tapping or even easier with a puller. There should be minimal oil loss, expect some, but no need to drain the box completely.
Post #1073467 16th Aug 2025 8:23am
cykoh85
Ok, thanks for your info Wink
Post #1073468 16th Aug 2025 8:32am
cykoh85
Yes, the picture I shared earlier was obtained from another forum.
The one I took myself wasn’t very clear, but I’ve uploaded it now—please have a look.
I’m struggling with the nut, as it’s very difficult to remove. So I was wondering, is there a circlip around it, or any clip that prevents the nut from moving?
thank you.
Post #1073469 16th Aug 2025 8:35am
Retroanaconda
The nut should just be a nyloc, but it will be very tight and the flange wanting to turn is a pain.
Post #1073482 16th Aug 2025 11:06am
cykoh85
@Retroanaconda, Any idea how to remove it? I used the diff lock and released the handbrake, but should I also engage 1st gear?
It’s really tight 😓 and I still failed to remove the nut.
Post #1073485 16th Aug 2025 11:54am
MarkBrown
Wales 1983 Defender 110 Other HT Auto Keswick Green
You can put some sort of bar above and below two bolts and turn the flange so the bar then jams against the chassis. It will probably bend the bolts and mash up the threads though, so you’ll need some new ones. 1983 110 automatic OM606
Post #1073486 16th Aug 2025 12:23pm
Retroanaconda
Put it in diff lock, first gear. Putting the drum back on and pulling the handbrake on might also help.
A 2’ long breaker bar should undo it, but if it’s not been off for a long time it may need an impact wrench or longer bar.
Post #1073489 16th Aug 2025 12:50pm
htb2
Wales
When refitting the oil seal is fitted flush with the casing or pushed in till it bottoms out?
Post #1073491 16th Aug 2025 12:59pm
cykoh85
Alright, I will give it a try and see. thanks Bruv!
Post #1073495 16th Aug 2025 1:58pm
cykoh85
Ok, looks like I need to buy a long breaker bar, since I was using a normal ratchet with a metal rod.
Thanks Bruv!
Post #1073496 16th Aug 2025 2:04pm
cykoh85
I want to know this too, waiting for someone experienced to answer. Very Happy
Post #1073497 16th Aug 2025 2:06pm
MadTom
Nylock nuts often get very tight over time, so realy big breaker bar and some angle plate with holes tightened to the propshaft flange and jammed to the ground should help. Holding it just by the gearbox is not the bets idea. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #1073504 16th Aug 2025 5:01pm
cykoh85
@MadTom - Ok, I’ll get the items first and try this method to see how it works. Thank you.
Post #1073538 17th Aug 2025 2:29pm
