Home > Maintenance & Modifications > 110 Rear Valance panel replacement
Icklerox2
Hi folks,
Has anyone any experience of replacing the rear valance panel? It looks simple enough!
https://www.lrparts.net/mrc6437-defender-l...ender.html
Thanks
Post #1073091 10th Aug 2025 3:27pm
donmacn
It is fairly simple. Just drill out the pop rivets, and it should wiggle free.
However….. the issue is usually more about whatever horrors you might find behind it. That part of the ‘C’ pillar, joined on to the sill, is a bit of a rust trap… Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #1073095 10th Aug 2025 4:49pm
Icklerox2
Ok, thanks, I will order them then and give it a go! Yes, given the current panels have corroded thru I am guessing it will be messy inside! It’s a 2016 model but I seem to have a lot of galvanic (?) corrosion.
Post #1073097 10th Aug 2025 5:06pm
