![]() | Home > Tdi > Setting the timing belt tension - torque wrench type |
julian Member Since: 17 Feb 2017 Location: Devon Posts: 204 ![]() ![]() ![]() |
I've got one of those cheap needle type ones. Had it for years.
I'd rather one with the dial. But I don't have one. I've done a number of 300 belts. |
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1917 ![]() ![]() |
I’ve only done the job a couple of times. I used a beam type, but needed to get one especially so that it had a decent enough range over the torque (only 11Nm or something small like that?)
I thought that if I used a larger one, with a wider scale, I wouldn’t really be able to gauge any movement of the needle. Probably over-thinking it (as usual…)! Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2785 ![]() ![]() |
I’ve done loads of belts with the beam-type and never had an issue. As above get one with an appropriate range that means the scale is easier to read.
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 683 ![]() ![]() ![]() |
A modern digital torque wrench will allow you to see the actual torque being applied. I have always used Snap On Techwrench / Angletech digital wrenches but nowadays there are cheap copies of these wenches at 1/10th of the price which would do the same thing.
Back in the early days I had an MHH Torqueleader dial wrench for the 300 tensioner which was the recommended factory tool, I expect these could be picked up for next to nothing on eBay. |
MercianRover Member Since: 07 Apr 2022 Location: Culworth Posts: 166 ![]() ![]() ![]() |
Thank you for the replies, I'm considering buying one of these:
https://www.parktool.com/en-int/product/be...-nm-tw-1-2 I looked at the MHH Torqueleader on ebay but the few I found had a minimum reading which was too high for this task. |
^^ I think that’s exactly the one I bought for this job.
![]() 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
