![]() | Home > Td5 > Crankshaft position sensor issues |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5991 ![]() ![]() |
You sure it’s not the immobiliser kicking in?
Your first sentence sounds like it. How old battery in fob? |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17933 ![]() ![]() ![]() |
The crankshaft position sensor is needed for the engine to run. The camshaft position sensor is only needed for the engine to start.
Mr.Jimbo Member Since: 20 Jun 2024 Location: Rugby UK Posts: 18 ![]() ![]() ![]() |
Fairly sure it’s not immobiliser - as I’ve had the same but get a red EML with a lightning bolt before which a quick lock/unlock sorts it (tried that several times but no joy) Occurrence 1 was a lock/unlock prior to issue, occurrence 2 today it remained unlocked as I was just filling up.
I did wonder if it might be something like cam sensor not achieving sync, but strange that it fires up right after I mess with the crankshaft sensor. Edit I should say, on the two times it does it I have no dash lights out of the ordinary, just the oil pressure which goes out with a bit of cranking and the charge light. No indication at all from the car that it shouldn’t start. It’s also a 2003 15p 110 |
