Home > General & Technical (L663) > Idle speed D250
lightning
Idle speed D250
To anybody with a D250 what RPM does yours idle at?
l am sure mine has gone up, it's now just under 750 rpm and l am sure it was nearer 650rpm before.
Post #1072584 31st Jul 2025 6:19pm
J77
Mine tends to go up slightly on hot days. 24MY 90 D250 HSE, Tasman Blue
Post #1072585 31st Jul 2025 6:45pm
Snipperty
I’ve found in mine it depends on the state of the battery and when it’s doing a refresh of the diesel particulate filter. Noticed it tends to idle at a slightly higher rpm if I’ve done several short journeys, suspect that’s related to charging the battery.
Post #1072693 2nd Aug 2025 5:04pm
XplusYplusZ
Today I noticed mine idling a little higher/louder than usual at a traffic light..
Coincidence - or was there a recent OTA update?
Post #1072760 4th Aug 2025 11:16am
lightning
Could be a DPF regeneration taking place?
Post #1072862 5th Aug 2025 7:46pm
Landy240
I have a D250.
It's hard to be absolutely exact but I would say idle is around 625rpm. Halfway between the 500 and 750 marker on the digital dial.
This is with stop/start activated so obviously no regeneration or similar taking place. I bought the car new just over a year ago and it hasn't changed at all.
Post #1072912 6th Aug 2025 7:50pm
Landy240
If it helps, regeneration is just under 1000rpm iirc
Services (aircon etc) will push the revs up a bit.
Post #1072914 6th Aug 2025 8:17pm
lightning
Landy240 wrote:
I have a D250.
Yes mine was always there but it's risen to around 700rpm
l don't suppose it really matters, that the idle speed has risen by 60rpm, but l did notice the change.
That's with nothing turned on and the stop/start turned off. Although turning things on makes no difference.
l wonder if the battery is deteriorating. l've read that some people have needed a battery replacement after as little as two years.
Post #1072920 6th Aug 2025 10:41pm
haymeister
Japan
Mine's a D300. With summer in Tokyo my idle speed in Drive has gone up by ~100rpm from 650 to 750rpm
In Park it rises to 950 rpm.
Outside temp indicated at 37 degrees on the dash. Aircon set to 22 degrees.
Coming up to my 4th year. At my 3rd year service they told me to replace the battery next year but no starting nor electrical issues (yet....) 22MY Defender 110 D300 S in Pangea Green and Contrast White Roof
IG defender_japan "Hulk san"
Post #1072923 7th Aug 2025 3:22am
