Home > Td5 > Swivel Pin Preload / Shims
CJs110
Canada 2003 Defender 110 Td5 SW Zambezi Silver
So working my way through the possible causes of death wobble (panhard rod bushes now sorted lol).
Next on the hit list was swivel pin preload.
Found a post on another forum, super informative. Tie rods off, fish scale used to measure - target range of 12-14lbs of force.
Off the bat, both side basically flopped side to side. Like 2lbs of force needed to move from stop to stop literally no resistance. Started with RHS first, there were 4 shims, dropped down to 2 and when tightened and torqued up I hit the target of 14lbs of force on the scale to move that knuckle stop to stop. Great!
Then got to the LHS (driver for me LHD) - remove the swivel pin and guess what only 2 shims to begin with. Removed 1, not enough. Removed both and its now just the pin directly to the housing, torqued up and I get between 8 and 10lbs of force needed to move from stop to stop. Where do I go from here? There aren't any more shims to remove!
Another point to note, I bought new shims/pins but I could not use the new pins as my ABS sensor got stuck only halfway in. Chalking it up to cheap parts.
Vehicle still on stands, doing a brake service before I go test it out. But I can already tell the steering feels tighter even though I wasn't able to reach that 12-14lb window on the LHS.
Post #1072381 28th Jul 2025 8:24pm
MarkBrown
Wales 1983 Defender 110 Other HT Auto Keswick Green
Personally I’d say the left one will be tight enough. If I remember mine ( older 110) are set at 4.5 kg, once the initial stiction is overcome. 1983 110 automatic OM606
Post #1072389 28th Jul 2025 9:05pm
Dinnu
Which axle do you have? The earlier Railko bushes have more preload than the later taper/roller bearing at the top. Your figures suggest you have the Railko. Note that preloads are stated without swivel seals.
Edit. I realize that you posted in the Td5 section, so if original axle, would be a taper roller bearing. I think your preload values are quite high. Dont remember the values, and no WSM at hand but also sure there have been many threads on this forum about preload values. Perhaps a search can get more info. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1072391 28th Jul 2025 9:19pm
donmacn
I’m not so good with Lbs vs Nm..!
As you probably know, to do this properly you also need the swivel seal removed. I’ve seen figures quoted for doing the preload with the seals still in place, but it’s a bit of guesswork.
If you’re having issues, you might want to think about taking the seals off? Messy and unpleasant, with lots of cleaning up involved - but you’d be “doing it right”.
On the question of low values, even with no shims, I wonder if you might have issues with an out of spec or worn swivel bearing?
Edit: Just after I read this thread, and posted, I found something else that might be directly relevant.
It's towards the bottom of this thread on another forum (hoping it's OK to link to this Martin?) https://lr4x4.com/topic/118680-worn-swivel...nt-1112239
In particular Retro says: "Yes the top pin forms the inner race of the bearing on Td5 onwards. Allows for ABS sensor on vehicles equipped as such."
I think I have a Td5 axle casing, but Tdi axle ends... (so what do I know!?)... but I hadn't realised that on the later axles the top swivel bearing acts directly on the pin. In which case, if you're trying to set your preload with the old pin and bearing, I reckon wear in both of these could be why you're not getting enough resistance? Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #1072406 29th Jul 2025 8:31am
Johan_B
Sweden 2007 Defender 110 Puma 2.4 CSW Tonga Green
I did one of mine last year (Puma 2007) and if I remember correctly the target was around 1,45kg with a fish scale. IF my memory is right AND we have the same type of axle, then your values seem to be high, even on the left side.
I found it really tricky to get a good reading. First you need to overcome the initial resistance (which will produce a higher value), then you need to pull with constant speed while keeping the scale perpendicular to the swivel arm and reading the value.
With your chassis id you should be able to see what axle type you have unless modifications have been made.
Post #1072409 29th Jul 2025 10:38am
4RF RDS
I believe one is supposed to remove the swivel seal to set the preload BTW.
Good luck. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
H. L. Mencken (1880 - 1956)
Post #1072432 29th Jul 2025 5:26pm
CJs110
Thanks all for the feedback. For removing the oil seal are you all just removing it from the back of the hub and just leaving it kind of hanging there on the axle shaft (to remove /replace an oil seal need the hub off correct?)
I was debating if I wanted to my oil seals as well.
I'll need a bit a of free time to tackle this again if I'm removing the oil seal, will report back what I find out. Wondering also if that 12-14lb range is still ok? I didn't see the actual spec for a TD5 ABS axle
Post #1072806 4th Aug 2025 7:13pm
donmacn
That’s it - just pop it off, and let it hang out of the way, but be sure to have an oil catcher and plenty of rags/paper to hand when you do…
There is a way to replace the seal without removing the swivel - a “field repair” that involves carefully cutting and gluing the seal and its internal spring, and fitting the join towards the top. I did this once and it remained happily in place for at least two or three years. I know I found some instructions for this online somewhere.
Sorry I can’t offer any advice on the tension setting, but these ABS axles are too new for me. I don’t imagine it’s very different than the older ones but best for me not to comment.
If I was doing this and I had a choice of marginally too tight, or marginally too loose, I’d go for the tighter setting knowing that whatever I did it would loosen up pretty quickly anyway. Donald
in the past..
Post #1072810 4th Aug 2025 7:46pm
rustandoil
When I refurbished my swivels I seem to remember that it took a bit of digging to find the pre-load data ....I cant remember where I found it but I've made note in my Haynes manual....1.16 - 1.46kg
Let us know how you get on Thumbs Up
Post #1072839 5th Aug 2025 11:21am
