Home > Maintenance & Modifications > Best Donor Defender for auto / engine conversion?
Mr Fox
United Kingdom 2015 Defender 90 Puma 2.2 HT Keswick Green
Other than reading the older threads on here, I'm wondering whether those who have done an auto conversion (with or without an engine change) have any advice for the ideal base 90 vehicle?
Quite a few conversions are based on the TD5, is this an easier swap than a Puma?
TIA
Post #1072290 27th Jul 2025 3:39pm
TVR Tommy
United Kingdom 2000 Defender 90 Td5 Heritage LE Bronze Green
The zf4hp22 is an easy install onto a TD5 as you can take a box out of a disco 2 (electronic) and then buy a compushift. Or a cheaper option is a zf4 out of a disco 1 (hydraulic) mounted to a disco 2 bell housing. You should also consider fitting a v8 torque converter as they are bigger so have a lower stall speed. The td5 TC is a bit revy. Made even worse with a tuned TD5
You can put a zf4hp22 onto a puma TDCi you’ll need an Ashcroft bell housing.
People have started putting zf8 onto the back of TD5’s which looks like a nice option. Being a newer conversion there’s not a huge amount of info. Once there is I may go down that route.
Current I’m running a 90 td5, disco 2 box with compushift 2 with a v8 TC. It works well and you can get it to shift how you want it to.
Post #1072311 27th Jul 2025 7:38pm
jst
I have done hp22 to TGVs with some success. I say some as they were off roaders with gearing to suit and didn't do a massive amount of road miles so can't comment on them as daily drivers.
Last conversion I did was 6hp28 to m57 but note in your previous post you don't like the m57/auto conversion you drove. For me having driven and used various 300tdi autos, tgv autos, v8 autos, td5 auto in defenders the m57 auto conversion is far better suited than anymore the above.
Td5/8speed would be one I would like to try.
I do however feel most landrover defender engines are not best suited to autos. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1072319 27th Jul 2025 9:20pm
Mr Fox
Hi James, didn’t like the particular 90, not the M57 swap.
I’d liked the engine and trans, it was the actual vehicle which was a mess.
Post #1072322 27th Jul 2025 9:53pm
Mo Murphy
I put a BMW X5 M57n and 6hp in my 90. I wouldn't go back to the Tdi it had before.
50 Shades of Pennine Grey
Post #1072337 28th Jul 2025 10:32am
V8Simon
United Kingdom 1985 Defender 90 V8 Petrol SW Auto Arles Blue
I've a 25+ year old conversion in my V8 90 which was an Ashcroft supplied ZF HP22 which has been faultless and was setup perfect out of the box. Mine is standard but has the bigger torque converter as mentioned.
If I was going down that route again, I'd be looking for a newer type of auto, not that there's anything wrong with a HP22, but just to future proof parts and add any functionality that comes as standard with the newer stuff. Very Happy 1984 90 V8 puma want to be.
Post #1072362 28th Jul 2025 3:20pm
MarkBrown
Wales 1983 Defender 110 Other HT Auto Keswick Green
I’ve had a few autos.
Disco 2 4.0 with the ZF hp22 - the engine was a bit gutless but I liked the auto.
I tried a 110 with the 300 tdi and the earlier hydraulic ZF hp22 - this was smooth but about as quick as a lawnmower.
My current 110 has an OM606 Mercedes engine and has a modified ZFhp24 with the middle sized torque converter - to work better with the engine - and is hydraulically controlled. This is smooth and suits both the engine and vehicle well.
I’ve had three Mercedes cars and a Jeep with the 5 speed 722 gearboxes, these have all been excellent.
I’ve currently got a seven speed automatic Sprinter, that’s really good. I’ve no idea what gear it’s in, but it’s always the right one.
If I were to replace the gearbox in the 110, I would go for the six or eight speed ZF as I think these would make acceleration quicker, quieter and more effortless than the current 4 speed. It would probably be more economical too. 1983 110 automatic OM606
Post #1072387 28th Jul 2025 8:59pm
Mr Fox
The more time I've spent looking at this, the more I'm leaning towards doing the auto conversion to a Puma 2.2/2.4
Does anyone have any advice with regards to this route?
It looks like Ashcroft are the only people supplying and carrying out the conversion (as JE seem to have closed their doors).
I've also read the older threads on here but generally they seem to have the same approach:
Hp22 - 4-speed - old tech
Ford Ranger 6-speed - more modern (was being fitted by JE) - but pricey
Any other info welcome!
Post #1074494 1st Sep 2025 1:50pm
